clutch's the same?
Old Oct 10, 2003 | 11:30 AM
phatrick2332's Avatar
Default clutch's the same?
I have a 91 SI tranny in my EF. I just got a complete z6 but it will be getting built. I noticed that it had a damn near new clutch in it. Can i put the everything from flywheel to pp. on my ef tranny? I believe the z6 is out of a 94 si/ex
Old Oct 10, 2003 | 03:57 PM
Malgerus's Avatar
Default Re: clutch's the same? (phatrick2332)
I am 99 percent sure it will work.
Old Oct 10, 2003 | 10:05 PM
wronghand's Avatar
The flywheel and the clutch disk will work. Not sure about the pressure plate. I think they are different. Remember the Z6 is hydro. I am not 100% sure. Just something to watch out for.
Old Oct 10, 2003 | 10:12 PM
Mista Bone's Avatar
D Tranny Guru
1990-2000, all use the same clutch setup
Old Oct 11, 2003 | 02:20 AM
-slow ej-'s Avatar
Default Re: clutch's the same? (Mista Bone)
just got my done,,,P&p easy easy easy... but some reason its still slow...*sigh*...need something to help me out
Old Oct 11, 2003 | 05:10 AM
USDM 4G VTEC's Avatar
Default Re: clutch's the same? (-RsINtEg-)
why not a 40 shot N2O for now?
Old Oct 11, 2003 | 05:34 AM
LoL...thanks 4G
Old Oct 11, 2003 | 09:38 AM
Starbucks_91b16acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">1990-2000, all use the same clutch setup</TD></TR></TABLE>
you sure .. i always thought hydro and cable clutches where different
Old Oct 11, 2003 | 11:00 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: clutch's the same? (91b16aCRX)
I'm running a 90-91 CRX Si clutch in my 1993 DX HB with Z6 motor.
The only difference is the throwout bearing in the clutch kits.
Now for a trick trivia question.........
What Civic model went BACK to the 200mm clutch disc????
Hint 6g model.
Old Oct 11, 2003 | 02:23 PM
so..i have to use the 91 throw out bearing..correct?
and i dont have the darndest clue..97
Old Oct 11, 2003 | 02:36 PM
zCivic's Avatar
Default Re: (phatrick2332)
I had a 92 C/F D/F (dang POS) clutch disc and p-p with my 90 SI tranny. The only difference is the throwout bearing
yo bj
Aug 29, 2009 07:50 AM
SiR eF_4door
Jul 31, 2009 08:15 AM
pinecone
Jun 22, 2006 05:27 PM
90 Si Hatch
13
Jul 9, 2005 11:15 AM
othick
Apr 14, 2005 06:12 AM
