Blown tranny, what could've happened?
Hi, last night I was taking off from a light [not dumping the clutch or anything], and was accelerating somewhat aggressively, when shifting into 3rd the car free-spun like in neutral. I thought I missed 3rd but tried going back into 2nd and it went right into 2nd gear position but didn't engage the gear, and it also did that for 1st, when I pulled over I thought I broke an axle, but didn't hear anything [from the front-end], so I tried going into 1st and it didn't engage either. Now the car doesn't even engage 3rd, 4th, 5th or reverse, only shifts to the 1st-2nd position. I didn't see any leaks under the car BUT the housing did have a crack in it [I just added 1qt honda mtf about a week ago]. Earlier the day it was popping out of 5th gear on the highway + 3rd on the streets when I would feather the gas. what could've blown? synchro's + diff? Any help would be appreciated, thanks.
-l8r
PS. Its a hydro b-series tranny, thanks
-l8r
sounds like the shift selector is checked out
pull the tranny separate the housing and investigate ..9 outta 10 times its somethin that can be repaired fairly quickly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed »</TD></TR><TR><TD CLASS="quote">Sounds dumb, but are you SURE its a crack? Could be a casting mark from when they are made. </TD></TR></TABLE>
naa, I'm pretty sure its a crack, there was fluid leaking from there since I've put it in. I've been monitoring it and adding fluid as necessary but I apparently something went and its gotten worse.
92EG8
May 16, 2007 06:46 AM
PM me, let me know!!!
