valves on skunk 2 stage 1 cams???
Old Oct 9, 2003 | 10:58 PM
all_stock's Avatar
Default valves on skunk 2 stage 1 cams???
what would you guys recomend setting the valves at on a b16 with stage 1 cams. cause my motor is in need of a valve adjustment.
Old Oct 10, 2003 | 06:36 AM
TimoneX's Avatar
New User
Default Re: valves on skunk 2 stage 1 cams??? (all_stock)
You should follow the recommendations of the cam manufacturer. Failing that Honda's recommended lash settings probably won't do you too wrong.
Intake: .15 - .19mm
Exhaust: .17 - .21mm
Power Rev Racing
May 26, 2005 08:56 PM
THCk20eg
May 23, 2004 10:13 PM
nY's FiNeSt
May 3, 2004 08:10 AM
rathead
Mar 4, 2003 07:49 PM
