Rev limit at 6000?
Old Oct 9, 2003 | 09:09 PM
Mr.DC2TurBo's Avatar
Default Rev limit at 6000?
I have a LS obd1 ecu with a chip that suppose to let me raise the limitor to 8500. Now, when I try to rev pass 6000 it feels like a rev limit and the neddle jumps back and forth and I can't go pass it. No codes either and when I try to put back a stock ls ecu it's still the same. What could be the cause?
Old Oct 9, 2003 | 10:31 PM
Lysawy's Avatar
Default Re: Rev limit at 6000? (Mr.DC2TurBo)
limp mode check for codes.
Old Oct 10, 2003 | 02:22 AM
jde_07's Avatar
I would double check that the ecu has been chipped because I know that had the same problem that you are having and the ecu chip wasn't burned right and he had it switched free of charge. Or it could be a interal engine problem that won't let it rev that high but with no engine codes it is hard to say.
Old Oct 10, 2003 | 06:12 AM
Default Re: Rev limit at 6000? (jde_07)
wat kind of intern can there be? I have no cel or anything. I bought the car used and it had an aftermarket dial but I was hitting pass 6K before. I use to be obd2 but I changed to obd1. I tried the stock ecu and it still did the same... can my tach be off by a 1K rpm?
nuber1zero
May 15, 2014 04:23 PM
OFM_DC2
May 20, 2010 05:53 PM
respectblades
Jan 19, 2005 07:14 AM
Mr.DC2TurBo
Oct 5, 2003 09:20 PM
