Honda S2000 Honda S2000
used s2000 questions
Old Oct 9, 2003 | 08:36 PM
JforJonathan's Avatar
Default used s2000 questions
if i was looking into buying a used s2000, what would i look for...what price would be reasonable for each year? basically...i just need to know what to look for: mileage, price, condition?
Old Oct 9, 2003 | 09:11 PM
AU K20A2's Avatar
Default Re: used s2000 questions (Dj Villain)
-Ask and if the clutch has been replaced and make sure it has been replaced with a 2002+ clutch.
-Of course ask and check for body damage.
-Obtain all service records if possible (make sure the differential fluid has been changed)
-Tire wear
-etc.
Old Oct 10, 2003 | 11:57 PM
oos2kfan
Guest
Posts: n/a
You should be able to pick up an 00 model for 18-21 and an 01 for 20-23. Check autotrader.com they usually have a lot of S2K's listed there. As far as what to look for...if it's pre 02 make sure any recalls have been done to the car. I believe there was one on the oil jet bolts and the transmission grind (1st - 2nd) but check to make sure this is correct. You can typically find them with low miles and preferably garage kept. I have unfortunately left mine in the texas heat and the paint is peeling and cracking on the front drivers side fender (Warranty is covering this though, 5 year paint warranty).
jabuhanna
Honda S2000
17
Mar 24, 2011 09:14 PM
JPT1
Honda S2000
13
Mar 6, 2008 02:04 PM
J's_Racing
Honda S2000
Apr 28, 2007 05:50 PM
Dongoesby
Honda S2000
13
Feb 16, 2007 09:04 AM
Paul Bosworth
Honda S2000
15
May 7, 2004 10:37 AM
