valve adj time? pinging / tink noise comming in very low rpms
Old Oct 9, 2003 | 08:03 PM
SsTiNgEr77's Avatar
Default valve adj time? pinging / tink noise comming in very low rpms
usually in 1st / reverse and shifting to second.. i will hear a tiny.. tink.. tink... noise comming from the driver side of the car?...
Most of the things i have read are that h22's need valve adjustments around 75k cuz of the pinging noise... My original thoughts were that my fuel filter line is busted because of a tiny twist in it.. but that doesn't seem to be the case because it only happens in 1st / reverse and 2cd at low rpms.. could it be something wrong with he oil pan? car burning oil?
could this be a transmission problem?
Old Oct 9, 2003 | 08:12 PM
satan_srv's Avatar
Default Re: valve adj time? pinging / tink noise comming in very low rpms (SsTiNgEr77)
valve adjustments are every 25k aren't they? If your valves are noisy they are noisy all the time even at idle.
Low rpm noise...hmm auto-tensioner for timing belt?
Old Oct 9, 2003 | 08:17 PM
Cottonwoodz's Avatar
Default Re: valve adj time? pinging / tink noise comming in very low rpms (satan_srv)
15K
Old Oct 9, 2003 | 08:18 PM
satan_srv's Avatar
Default Re: valve adj time? pinging / tink noise comming in very low rpms (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">15K</TD></TR></TABLE>
lol sorry I'm canadian 15k miles = 24k kms
Old Oct 9, 2003 | 10:42 PM
SsTiNgEr77's Avatar
how much would a valve adj. run?
can i do this myself?
im prob gonna switch to a manual tensioner... cuz lotta ppl running that say its much better
Old Oct 16, 2003 | 04:46 PM
SsTiNgEr77's Avatar
Just got a valve adj, car still tinks at low rpms in 1st / reverse... usually just going real slow
what is problem maybe?
shop said could be something loose vibrating, i dont believe so because it only happens at certain rpm... maybe a arm has something loose?
any ideas?
vdawg559
Jul 20, 2008 02:15 AM
GSRBrent
Dec 2, 2007 09:25 PM
sector001
Oct 13, 2006 12:09 PM
For_Sale
Jul 12, 2006 10:50 AM
fynal
Mar 22, 2005 05:05 PM
