Brake lights dont work??
ok so i checked all the fuses and replaced the brake light switch by the pedal and my brake lights still dont work!!!
what else can it be?? are there more than one fuse for thebrake lights??
any help would be appreciated asap, i am not able to drive
Modified by JdmGlenn at 5:11 AM 10/10/2003
I replaced all the bulbs , the signal light, and all the lights work BESIDES the brake light, i am still clueless ,
WHERE is the ground for the brakign??
Thanks GUYS
Thanks GUYS
i had that same prob with my car when i bought it,,,whenever i put a fuse in it would break when i applied the brake,,,turned out that the brake lights and the horn share the same fuse,,i looked at my horn and one of the wires was disconnnected and touching the car makin it short,,so check your horn and wires
ok i tried everything you guys told me i changed the horn fuse along with every OTHER fuse and i checked all the grounds that were visible
my BRAKE LIGHTS still dont work
what else could it be????
ANY help is APPRECIATED thanks GUYS
what else could it be????ANY help is APPRECIATED thanks GUYS
CrazyRexBoy
Jan 13, 2007 07:14 PM
