how do you make the passenger window go up and down with one touch of button?
There's bound to be someone out there who has done it already. It's definitely possible. I'd like to know too.
http://www.autoloc.com you can make all of your windows full auto.... there is a kit...
figure out how the driver side is set up and copy it... you'd have to buy a few things....maybe from a junk yard, but I'm sure its possible.
I don't know if this is what you had in mind, but if you have a clifford alarm system, you can add their smart windows module (retail $100).
Not only will you be able to roll down/up the passenger side w/ a single touch, but it'll also allow you to roll down (or vent) your car and roll up when you manually arm your alarm, from your button remote.
[Modified by gsr.sedan, 2:18 AM 8/30/2001]
i have it on mine. auto roll up or down both driver and passenger window from drivers side. its a module that is wired into ur alarm. i have a modified black widow alarm. it works great. i can roll my windows down with remote but only down.
when my car is armed, i can leave windows down and when i hit my remote the windows will roll up
at the time i did not have enough cash so window down was the only option. i plan to upgrade soon to where i can roll up or down with remote armed or disarmed.
hope this helps...
hope this helps...
Maybe its all in the switch? I thought just replacing the regular switch with one like the driver's (labeled auto) would take care of it.
Hey stick, how do like your dunlops? Any comments good or bad. I think I will pick up the SP 8's within the next sixth months
Find a good wiring diagram. I looked in my chiltons manual, but it sucks, it doesn't have diagrams for the window switches. Find one that does and you find out how to do it.
I know there has to be a way to do it w/o buying an alarm.
Both window switches on the driver's side are integrated into one module. It would not be very straightforward to replace the driver's side passenger window switch with another auto switch.
HTH, Rainmaker.
HTH, Rainmaker.
mickey513
Audio / Security / Video
Jun 29, 2003 09:42 PM
