n e 1 try cutting out spare tire well for weight reduction>?
Old Oct 9, 2003 | 07:15 PM
project dc2's Avatar
Default n e 1 try cutting out spare tire well for weight reduction>?
heheh just a curious thought .. anyoine here try cuttong out the spare tire well and bracing it .. kinda like back halfing it and see how much weight is saved ?
Old Oct 9, 2003 | 07:25 PM
ExospeedAMcrx's Avatar
Default Re: n e 1 try cutting out spare tire well for weight reduction>? (project dc2)
dont cut it.. its not worth it in MOST cases.
for one thing.. if the car is ever going to race any Race series, some may not allow it in your class.
Old Oct 9, 2003 | 07:26 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
A while back I think Lawrence at Dynospot Racing had a drag car with the spare tire well cut out in his shop. You can try calling him and asking him about it. Although, this was a couple years ago.
Old Oct 9, 2003 | 07:38 PM
DaveF's Avatar
Default Re: n e 1 try cutting out spare tire well for weight reduction>? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">dont cut it.. its not worth it in MOST cases.
for one thing.. if the car is ever going to race any Race series, some may not allow it in your class. </TD></TR></TABLE>
Agreeed good advise.
Old Oct 9, 2003 | 07:50 PM
Gravy's Avatar
Default Re: n e 1 try cutting out spare tire well for weight reduction>? (2.2Lcivic)
you would think that by cutting the spare tire well it would help but the thing only weighs like 1 pound.
Old Oct 9, 2003 | 10:17 PM
GSRswapandslow
Guest
Posts: n/a
that thing weighs more than 1lb!
that's some semi thick ****
i was thinking about cutting it out and replacing it witha piece of sheet metal and an x-brace where the hole was
Old Oct 9, 2003 | 10:25 PM
Default Re: (GSRswapandslow)
by cutting it, you may drop about 15lbs? on that spare tire area. but by putting a brace to make it as safe and rigid like before will add you another 5lbs.
All that work for 10lbs. We've cut up cars back in the day.. and it just wasnt worth it in the long run. Class rules, track rules change so often that it may affect the ability of the car to run at the track/racing series.
Old Oct 9, 2003 | 10:40 PM
genius's Avatar
Default Re: (exospeedAMcrx)
it weighs like 7 lbs...not worth it...trust me...one thing i regret doing the most
Old Jul 19, 2004 | 02:40 PM
JR Integra's Avatar
Default Re: (genius)
lets see a pic
Old Jul 19, 2004 | 07:22 PM
.dave's Avatar
i HAS questions ?
Default Re: (JR Integra)
If you're going to cut it out, definitely put a thin piece of sheet metal in to replace it. Otherwise you're going to need a lot of "speed holes."
Old Jul 19, 2004 | 07:29 PM
Jokerluv's Avatar
"anyone"
Old Jul 19, 2004 | 10:55 PM
menkio's Avatar
Default Re: (Jokerluv)
no, don't cut it.
Old Jul 19, 2004 | 11:40 PM
Drag_Racer_DRU's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genius &raquo;</TD></TR><TR><TD CLASS="quote">it weighs like 7 lbs...not worth it...trust me...one thing i regret doing the most</TD></TR></TABLE>
everyone regrets it, its totally not worth it... and it really does just weigh around 10 lbs
Old Jul 19, 2004 | 11:43 PM
Sinisterprostok's Avatar
I cut mine out an replaced it with .032 alum. Depending on how far you cut,I was able to pull 70lbs or so.(including the gas tank,filler neck,lines, straps,etc.)I added a 5 gal. fuel cell and put gas in through the rear hatch.Ive done this to 4 other cars and the integ was able to lose 85 lbs but I went all the way to the front seats. Exospeed is right,you'll get hastled at almost every event you go to.I just did it cuz I wanted to go fast.214whp 141 tq.1870 lb eg=11.91 @ 113.
Old Jul 20, 2004 | 02:24 AM
DaveF's Avatar
Default Re: (Sinisterprostok)
**** cutting that ****.... it makes the bottom of the car more flat and also aims the air, under the bumper, isntead of directrly into it.
the toe hook is way more important.
Old Jul 20, 2004 | 07:40 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinisterprostok &raquo;</TD></TR><TR><TD CLASS="quote">I cut mine out an replaced it with .032 alum. Depending on how far you cut,I was able to pull 70lbs or so.(including the gas tank,filler neck,lines, straps,etc.)I added a 5 gal. fuel cell and put gas in through the rear hatch.Ive done this to 4 other cars and the integ was able to lose 85 lbs but I went all the way to the front seats. Exospeed is right,you'll get hastled at almost every event you go to.I just did it cuz I wanted to go fast.214whp 141 tq.1870 lb eg=11.91 @ 113. </TD></TR></TABLE>
Ummm, you can't have a fuel cell in the pass compartment..
Old Jul 20, 2004 | 07:55 AM
skunked's Avatar
Default Re: (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">
Ummm, you can't have a fuel cell in the pass compartment.. </TD></TR></TABLE>
you can if it's covered and sealed. I personally prefer to leave it how it is though.
mattEG
30
Mar 31, 2012 06:30 PM
trigun7469
21
Mar 17, 2006 04:08 PM
hondaguyef
Jun 28, 2005 12:29 PM
emwavey
Apr 30, 2004 12:59 PM
Civic242
Apr 11, 2003 05:40 AM
