Where do you guys put your 2 Step Button?
Old Oct 9, 2003 | 05:06 PM
kungfuSiR's Avatar
Default Where do you guys put your 2 Step Button?
I just picked up my MSD 2 step, and i wanted to know a good location to mount the button to switch between lauch, and my upper rev limit
Was thinking around where my ebrake is, anyone have pics of their placement or ideas?
Old Oct 9, 2003 | 05:34 PM
Jay Dirt's Avatar
Default Re: Where do you guys put your 2 Step Button? (kungfuSiR)
Ebrake handle is a good place to start, or you should look into a hydraulic handbrake like seen on all the pro cars, it sticks straight up and it's easier to work with, a switch off the clutch is also not a bad idea
Old Oct 9, 2003 | 05:49 PM
boostedh22a's Avatar
mine's on the cluth pedal. When the clutch pedal is pushed in, your in launch mode, when its not, your in High Rev Limit mode. Simple and you dont have to worry about a button or any visible wiring
Old Oct 9, 2003 | 07:45 PM
Racergurlie's Avatar
Default Re: (boostedh22a)
What he said...
We put ours on the clutch pedal too...put it so that its activated only when the clutch is pushed all the way in...That way, pull to the line, push the clutch all the way in and floor it! Whola, it'll go to your two step rpm, once you drop the clutch, it reverts back to your normal rev limiter...
Old Oct 9, 2003 | 08:01 PM
DaveF's Avatar
Default Re: (Racergurlie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racergurlie &raquo;</TD></TR><TR><TD CLASS="quote">What he said...
how is it for between shifts..
would it activate the 2 step....or do ya try not to push the clutch pedal too far?
Old Oct 9, 2003 | 08:04 PM
Gravy's Avatar
Default Re: (2.2Lcivic)
i say put it some place near the shifter. this way once you launch all you have to do is throw the button on the floor.
Old Oct 9, 2003 | 08:41 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">mine's on the cluth pedal. When the clutch pedal is pushed in, your in launch mode</TD></TR></TABLE>
Old Oct 9, 2003 | 09:02 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">
would it activate the 2 step....or do ya try not to push the clutch pedal too far?</TD></TR></TABLE>
yea what he said, cuz i havnt wired my 2step because i was thinking about that problem...
Old Oct 9, 2003 | 09:03 PM
3rdGteg's Avatar
Default Re: (BlueHatch00)
Where's a good place to get one of those msd 2-steps?
Old Oct 9, 2003 | 09:05 PM
1fasthb's Avatar
Default Re: (3rdGteg)
i think putting it on horn would be a good place. never seen it tho
Old Oct 9, 2003 | 09:13 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">Where's a good place to get one of those msd 2-steps?</TD></TR></TABLE>
summit racing
jegs
prolly the cheapest prices on msd you will find.
Old Oct 9, 2003 | 09:19 PM
ringgold's Avatar
I was looking at a 2 step today and was wandering the same thing. If i were to mount it where it was clutch activated wouldnt it try to activate the 2 step when I was banging the gears down the track and pushing down the clutch pedal?
Old Oct 9, 2003 | 09:28 PM
PHO-SHIZZLE's Avatar
Get a spiral cord button (similar to a phone cord) and mount it on your steering wheel
Old Oct 9, 2003 | 09:36 PM
DaveF's Avatar
Default Re: (ringgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ringgold &raquo;</TD></TR><TR><TD CLASS="quote">
I was looking at a 2 step today and was wandering the same thing. If i were to mount it where it was clutch activated wouldnt it try to activate the 2 step when I was banging the gears down the track and pushing down the clutch pedal? </TD></TR></TABLE>
yea. thats what i think..maybe if the rpms are so high it "overrides" the msd and it doesnt kick it in(the 2 step action) also.. a signal might need some throttle input as well..so if you are between shifts you would most likely have your foot off the throttle and that would cause the 2 step to not kick in.
im not completly sure how this works.
boostedhb's Avatar
You'll be fine between shifts, unless you shift like an old lady, when you have the switch activated you're probally racing which means you'll be shifting as fast as possible. None of our cars have ever had a problem with the switch being wired to the clutch pedal during shifting.
Old Oct 9, 2003 | 09:38 PM
DaveF's Avatar
Default Re: (boostedhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedhb &raquo;</TD></TR><TR><TD CLASS="quote">You'll be fine between shifts, unless you shift like an old lady, when you have the switch activated you're probally racing which means you'll be shifting as fast as possible. None of our cars have ever had a problem with the switch being wired to the clutch pedal during shifting.</TD></TR></TABLE>
what happens if i feel like being 90 years old for a minute...i dont wanna be shifting my *** off, chirping gears, driving around town in the middle of the day for no reason, ya know?
Old Oct 9, 2003 | 09:40 PM
boostedhb's Avatar
I dunno, try it and let me know what happens.
bambooluv's Avatar
you guys gotta drop jason p on here a line. ON his setup hes got some sort of switch where after the 2 step does its thing you cant activate again until you throw the switch again. jason wanna shed some light?-pdang
Old Oct 9, 2003 | 09:41 PM
dmotoguy's Avatar
i think you have to have the pedal all the way to the floor, with the ems you can set it so over a certain speed it wont activate.. say 10mph
Old Oct 9, 2003 | 11:24 PM
jdkindle's Avatar
Default Re: Where do you guys put your 2 Step Button? (dailydriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dailydriven &raquo;</TD></TR><TR><TD CLASS="quote">Get a spiral cord button (similar to a phone cord) and mount it on your steering wheel</TD></TR></TABLE>
I would recommend against that.......we had it that way on Brittanys car and it caused nothing but problems, so I put it on the stage brake and she likes it there
I like the clutch idea better, especially if you could incorporate the 10mph thing into that.............my stock ECU has that feature, so I know it can be done
maybe I'll just use my stock ECU next year.......I wonder if any pro car has ever used a stock ECU?
Old Oct 9, 2003 | 11:27 PM
V-SPEC 1's Avatar
Default Re: (1fasthb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fasthb &raquo;</TD></TR><TR><TD CLASS="quote">i think putting it on horn would be a good place. never seen it tho</TD></TR></TABLE>
Look in Erick's racing car, he had his in the steering wheel. Look in hondata site of his video.
Old Oct 9, 2003 | 11:29 PM
V-SPEC 1's Avatar
I have the msd digital 6 plus and have 2 step rev limeter on it. I want to know where I can find a good switch for the pedal activation? Thanks.
Vic
rOby's Avatar
Default Re: Where do you guys put your 2 Step Button? (jdkindle)
i like pushbuttons, ie 1horn button or near the bezel or shifter. clutch mounted scare me
Old Oct 9, 2003 | 11:56 PM
AdamBOMB_STi's Avatar
Default Re: Where do you guys put your 2 Step Button? (rOby)
i mounted mine on my steering wheel with a coiled wire connected to a push button switch i bought from radio shack. works great. but alot of people think its a nitrous button.
Old Oct 10, 2003 | 01:57 AM
integra_gsr98's Avatar
Default Re: Where do you guys put your 2 Step Button? (kwik_B16)
I've got some pretty whack wiring in my car setup for my two step and nitrous but it's good stuff. Relay's are your friend.
Relay one is attached to the horn buttons. Converts a negative trigger a positive trigger.
Relay number two is wired up like a starter kill relay. +12v trigger coming from the horn button relay, which completes the circuit for the resistors I have on a potentiometer for my two step. (using a potentiometer w/ resistors to fool the MSD 6AL I have into thinking it has a pill of a certain value in it).
I also then have a relay off of my clutch switch that breaks the signal going to the nitrous solenoids, making sure that when I am staged and on the two step it has not engaged the nitrous. Works quite well. :-)
