crazy oil burning problem/issue
Old Oct 9, 2003 | 04:35 PM
Grandprix's Avatar
Default crazy oil burning problem/issue
i was wondering if anyone else has experienced what I have been experiencing. I let the car warm up normal and everything. Then (the key part) on the first vtec of the day I'll get alot of smoke out my exhaust. Its white smoke. The higher the rpm, the denser the smoke. but the weird part, is I only get this big cloud of smoke on the first vtec of the day.
Its like theres a piece of something stuck somewhere, and it gets knocked loose.
Any ideas? I probably should just get a compression and leakdown test. My car has 102,000 miles on it. Use synthetic oil.
Old Oct 9, 2003 | 05:23 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: crazy oil burning problem/issue (Grandprix)
valve guide seals
Old Oct 9, 2003 | 05:31 PM
Mad Cow Disease's Avatar
if its only sometimes, when you left off the throttle its mostly likely valve guid seals.
high rpm will can cause your rings to burn oil if they are worn..
Also check your pcv valve.
Old Oct 10, 2003 | 05:53 AM
Grandprix's Avatar
Default Re: crazy oil burning problem/issue (tmc racing)
burns like a **** when i let off throttle. I put in a brand new PCV valve this spring, and didn't notice any change in behavior. I also tried switching oils too, but no difference. I will be so happy if it is valve guides!
Thanks Fellas
FeRReTTi
May 3, 2017 05:54 PM
Black R
Mar 28, 2011 05:42 PM
M@
Aug 23, 2005 09:24 AM
preludeguy_92
Jun 25, 2005 11:39 AM
Ri5e
Jun 20, 2002 09:31 AM
