EK seats into my CRX
Old Oct 9, 2003 | 04:26 PM
IDGAF2885's Avatar
Default EK seats into my CRX
I got a good deal on some EK seats and I wanna put them in my CRX. The bolts dont line up of course, and it doesnt look easy to swap the sliders either. Anyway if you know how to do this help me out, thanks.
Old Oct 9, 2003 | 05:40 PM
crxforum's Avatar
Default Re: EK seats into my CRX (IDGAF2885)
You can remove the pan from the bottom of the seats and swap those. The pans are like what the rails attach to. Some seats let you remove the pans.
CRX Forum
Old Oct 9, 2003 | 05:55 PM
Grease Monkey's Avatar
Default Re: EK seats into my CRX (crxforum)
or you can make your own brackets with metal plates from home depot.
My GSR Seats in my CRX
Old Oct 9, 2003 | 06:06 PM
IDGAF2885's Avatar
Default Re: EK seats into my CRX (Grease Monkey)
How did you make your own brackets with plates from home depot?
Old Oct 9, 2003 | 06:07 PM
metric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">You can remove the pan from the bottom of the seats and swap those. The pans are like what the rails attach to. Some seats let you remove the pans.
CRX Forum</TD></TR></TABLE>
crxforum is right. You could also do some fabrication like I did to get rsx seats to fit.
Old Oct 9, 2003 | 06:18 PM
MrTodd's Avatar
Default Re: EK seats into my CRX (2.0CR-XVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0CR-XVTEC &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Nice!!!
Old Oct 9, 2003 | 07:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDGAF2885 &raquo;</TD></TR><TR><TD CLASS="quote">How did you make your own brackets with plates from home depot?</TD></TR></TABLE>
Make measurements. Use cardboard as a sample. Make sure the length is correct. Make dots on the spot you need to drill and add bolts and nuts on the seats mounting holes and use you stock bolts to hold the other side of the bracket. i can take pics possibly tomorrow if you need me to.
Old Oct 9, 2003 | 07:25 PM
IDGAF2885's Avatar
thats cool. Thanks alot for the info and the offer to take pics.
Old Oct 9, 2003 | 08:03 PM
b16_madman's Avatar
ahhh i rsx seats. possibly the best yet.
Your seats are bagged-thro dem switches an give out a Woo Woo
Old Oct 9, 2003 | 08:15 PM
IDGAF2885's Avatar
Default Re: EK seats into my CRX (B16_madman)
so imake these adapter brackets and bolt them to the brackets on the seats and then into the floor in my car?, is that gonna raise my seats?, because if anything i wanna lower em.
Old Oct 9, 2003 | 11:36 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDGAF2885 &raquo;</TD></TR><TR><TD CLASS="quote">so imake these adapter brackets and bolt them to the brackets on the seats and then into the floor in my car?, is that gonna raise my seats?, because if anything i wanna lower em. </TD></TR></TABLE>
if you plan it out right it shouldnt raise the seats up any...A friend of mine made his own brakets to mount some teg seats and it did raise them up a bit.
Old Oct 10, 2003 | 04:49 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDGAF2885 &raquo;</TD></TR><TR><TD CLASS="quote">I got a good deal on some EK seats and I wanna put them in my CRX. The bolts dont line up of course, and it doesnt look easy to swap the sliders either. Anyway if you know how to do this help me out, thanks.</TD></TR></TABLE>
Dude . . .
'96-00 Civic seats are really bad. If you have an Si or DX, I would suggest to not waste your time. They sit very high, are uncomfortable, have very little lateral support, and hell they don't even look good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">You can remove the pan from the bottom of the seats and swap those. The pans are like what the rails attach to. Some seats let you remove the pans.</TD></TR></TABLE>
Pans will definitely not swap. '96-00 seats are significantly wider and also have a different design for the recline mechanism.
Old Oct 10, 2003 | 10:24 AM
IDGAF2885's Avatar
Default Re: EK seats into my CRX (Targa250R)
I hear what your saying but my CRX seats are falling apart and i think these seats do look good and are comfortable, CRX are way better though, i just wish they made me of better quality.
Old Oct 10, 2003 | 11:02 AM
HumanResource's Avatar
RSX seats
those things are porkers, was gonna use a pair but found out they're heavier than Si seats and they sit a lil taller
Old Oct 10, 2003 | 11:19 AM
BAZ's Avatar
BAZ
I wanna see EP3 (2003 Civic Si) seats in an EF.
They look sick!
Old Oct 10, 2003 | 11:32 AM
xsellxoutx's Avatar
dude put the seats in the car where you want them, mark the bolt holes, drill holes, then grade8 bolts/washers.
thats how my 91SIseats are in my 88hatch and my friends WRX seat are in his 90hatch
Old Oct 10, 2003 | 08:54 PM
IDGAF2885's Avatar
Default Re: (xsellxoutx)
bump
tougermoua
Feb 4, 2013 09:18 PM
Hidenplanvew
Apr 11, 2012 05:51 PM
Jorsher
Dec 14, 2006 09:32 AM
JMD
Jun 25, 2003 05:08 PM
dUnK
Nov 26, 2002 12:32 PM
