MPFI Swap
Old Oct 9, 2003 | 03:58 PM
Grease Monkey's Avatar
Default MPFI Swap
Before I start my mpfi swap tomorrow I wanted to know if I can use the existing fuel line to hook up to the mpfi fuel rail. Do I need to modify the line? Any bending or new fuel line? TIA!
Old Oct 9, 2003 | 04:19 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: MPFI Swap (Grease Monkey)
The line on the left is the DX line,the line on the right is the Si type line.
It has a larger opening on one side where it bolts to the fuel rail...
You could use a die grinder to open the DX line up..
The DX line feeds through the middle while the Si line feeds through the side hence the larger opening..
see the difference?
clic this: http://mediaservice.photoislan...4.jpg
if pic does not show..
Old Oct 9, 2003 | 04:27 PM
Malgerus's Avatar
Default Re: MPFI Swap (88DXCRX)
I don't think that I changed my line when I did the D15B2 to B16A swap.
Old Oct 9, 2003 | 04:49 PM
FourthGenHatch's Avatar
When I did my ZC Swap the DX fuel hose would not bolt to my ZC. So I got an Si fuel hose from the junk yard.
Old Oct 9, 2003 | 04:56 PM
Outsane's Avatar
Default Re: MPFI Swap (FourthGenHatch)
I should have one in my Garage..
give me $7 and I will ship it out to you...
Old Oct 9, 2003 | 05:00 PM
Default Re: MPFI Swap (Outsane)
But i need this tomorrow...... would a parts store carry this? I dont have a die grinder and I dont understand why most mpfi web sites did not mention this. Is there an easier way to get this done or i have to replace the hose?
Old Oct 9, 2003 | 05:03 PM
plonger's Avatar
I kept the std fuel line when i do the mpfi swap on my D15B1 and it fit like a charm
Modified by plonger at 2:14 AM 10/10/2003
Old Oct 9, 2003 | 05:05 PM
Outsane's Avatar
Default Re: MPFI Swap (plonger)
Honda has fuel lines..
Replaced a teg one a couple of weeks ago..
but in 88dxcrx's post he states the fittings are different. Did you have to modify it?
Old Oct 9, 2003 | 05:09 PM
Outsane's Avatar
I did not use a teg one... but I replaced the fuel line on an integra with an integra fuel line... I was just saying that you can get fuel lines at honda...
Old Oct 9, 2003 | 05:20 PM
Malgerus's Avatar
If it fits with no problem, then there is no problem... right?
Old Oct 9, 2003 | 07:04 PM
Default Re: MPFI Swap (Mr. S)
anyone else?
Old Oct 9, 2003 | 07:06 PM
USDM 4G VTEC's Avatar
all the honda fuel line that goes from the filter to the fuel rail are the same
they can all be used among no matter what fuel rail u got
i got the stock DPFI line and i have used Z6 and Y8 lines without leaks
Old Oct 9, 2003 | 07:10 PM
Default Re: MPFI Swap (USDM 4G VTEC)
thanks for your help guys.... i guess i'm going to have to wait and see whats going to happen tomorrow. I will keep you guys posted.
Old Oct 9, 2003 | 07:17 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">all the honda fuel line that goes from the filter to the fuel rail are the same
i got the stock DPFI line and i have used Z6 and Y8 lines without leaks</TD></TR></TABLE>
Alright, sounds good
Glad I don't have to dig up that Si line from under the piles of crap
Old Oct 9, 2003 | 10:38 PM
1CiViC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plonger &raquo;</TD></TR><TR><TD CLASS="quote">I kept the std fuel line when i do the mpfi swap on my D15B1 and it fit like a charm
same here! Kept my dpfi fuel line
Old Oct 10, 2003 | 02:49 AM
westcoastcat's Avatar
Default Re: MPFI Swap (1CiViC1)
bump bumper .. hey i just got a 89 std b1 hatch,, does the si head, si tranny, and mpfi, make a diff from the 70 hp? my block had 223k miles should i keep the block also?
Old Oct 10, 2003 | 02:58 AM
they can all be used among no matter what fuel rail u got</TD></TR></TABLE>
This is not a true statement, they are not all the same. I've had the DX, Si, and DA Integra fuel lines and they were all different. You could make them work but when I used the Integra line on my car the hose came in from the top instead of the bottom like it should and the hose was too short for my fuel filter to attached to the fire wall again. So do not try and use an Integra hose, everyone.
Old Oct 10, 2003 | 03:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">
This is not a true statement, they are not all the same. I've had the DX, Si, and DA Integra fuel lines and they were all different. You could make them work but when I used the Integra line on my car the hose came in from the top instead of the bottom like it should and the hose was too short for my fuel filter to attached to the fire wall again. So do not try and use an Integra hose, everyone.</TD></TR></TABLE>i think u misunderstood and i didnt explain a lot
on his case... a DPFI hose going to MPFI....
what i said was that the tip(conector) (not the lenght and other stuff) fo honda hoses ca be used among others..... for example.... on a STD or DX DPFI can u can use any fuel rail and it will bolt up to the existing fuel feed line
crex23
12
Jul 25, 2005 10:57 AM
FalkenSiR
Feb 16, 2005 09:22 PM
xvracing
Oct 3, 2003 05:53 PM
FourthGenHatch
Apr 16, 2003 06:20 AM
WhatThaFrig
Feb 23, 2003 11:23 AM
