getting code 16
Old Oct 9, 2003 | 03:35 PM
pinoyboy204's Avatar
Default getting code 16
sup everyone. i'm getting code 16 on my car which is fuel injection..what could be the problem and how can i fix it? thanks for the help guys!!
Old Oct 9, 2003 | 03:37 PM
USDM 4G VTEC's Avatar
Default Re: getting code 16 (pinoyboy204)
bad injector
or a bad conector
loose conector came off the injector
or a fracture in ur wiring on the injectors
Old Oct 9, 2003 | 04:14 PM
Default Re: getting code 16 (USDM 4G VTEC)
can you show me some pics of where i should diagnose the problem(s).?
Old Oct 9, 2003 | 04:57 PM
well take the plugs off the injectors.... use a ohmeter and check that the inj are 1.5-3.5 ohms each
make sure u get a resistance reading between the plugs and the proper terminal on the harness at the ecu
make sure the inj resistor its good (6-8 ohms)
lsvSwagg
Jan 29, 2013 07:46 AM
Red_ED8
Jul 15, 2010 11:19 AM
red91hatch
Jun 6, 2008 06:23 AM
mopar junkie
Mar 25, 2007 05:42 PM
delux247
Jan 28, 2004 11:48 AM
