Wheel bearing or axle, which is the problem?
Old Oct 9, 2003 | 03:22 PM
fstgsr's Avatar
Default Wheel bearing or axle, which is the problem?
My car is making a rubbing noise on the right side of the car when I go straight or turn left but ceases to make the noise when I turn right. I have had the wheel bearing replaced on the driver side wheel and am know wondering if the passenger side has to be replaced or is it the axle? I have also checked the rim for movement with the car off the ground and had no signs of play in it. The tires have also been balanced 2 times already. Please help me out to diagnose this problem. Thanks
Old Oct 9, 2003 | 04:30 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Wheel bearing or axle, which is the problem? (fstgsr)
Is it a constant rubbing sound when you're going straight? Have you checked to see if the tires are rubbing anywhere?
Old Oct 9, 2003 | 04:33 PM
TyPe_R_GuY's Avatar
my car does the same but it stops making noise when i turn left, i have replaced my drivers side axle, but not my passenger side axle, so i am right there with ya lol
Old Oct 9, 2003 | 06:50 PM
svtec's Avatar
L D E S
Default Re: (TyPe_R_GuY)
sounds like wheel bearings.
Old Oct 16, 2003 | 08:44 PM
CrazyHondaBoy's Avatar
How much is the wheel bearing to replace?
Old Oct 19, 2003 | 05:49 PM
imthedude's Avatar
well how low is your car if its too low it might be your axle but if it was a wheel bearing it would get louder when you go faster and it would be a squicking noise
Old Oct 19, 2003 | 05:55 PM
whiteboygsr's Avatar
Default Re: (imthedude)
Sounds an awful lot like the axle. My GSR was doing that for a few days after I replaced the driver side axle. I would only do it during acceleration going straight or turning right. But not turning left. Turned out that the axle hadn't been fully engaged with the halfshaft. After putting it in properly the problem went away.
Modified by whiteboygsr at 5:13 AM 10/21/2003
Old Oct 20, 2003 | 06:47 AM
fstgsr's Avatar
Default Re: (whiteboygsr)
Now Im thinking it could be the axle because it started sounding worse and vibrating progressively after I had my axles replaced.
Old Oct 20, 2003 | 06:49 AM
BigC-ivic's Avatar
agreed
I say axle... check if the boot has a small rip in it... the grease could have leaked out and your axle could be wearing pretty bad
Old Oct 29, 2003 | 09:03 AM
fstgsr's Avatar
Default Re: (BigC-ivic)
It turned out to be the wheel bearing.
Knightrider03m
May 29, 2013 05:06 AM
efsex
Jan 9, 2010 11:52 AM
BOOSTED_JDM_DB8
Dec 26, 2007 12:15 PM
dc2doi
Oct 15, 2007 11:23 AM
REDBARON
14
May 24, 2001 07:25 PM
