WHOA.. whos running 86MM pistons in there B-SERIES??
Old Oct 9, 2003 | 03:18 PM
JunIntegra's Avatar
Default WHOA.. whos running 86MM pistons in there B-SERIES??
i noticed that there are sleeves in 86mm. really curious on the pros/con on this and why more people dont do this?
Old Oct 9, 2003 | 04:15 PM
JD Milan's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (JunIntegra)
that is pretty big, probably cuase the cost of the pistons for that size bore might cost some cashish. NOt sure if that size is customer made but more than likely.
Old Oct 9, 2003 | 04:21 PM
junya16's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (JD Milan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD Milan &raquo;</TD></TR><TR><TD CLASS="quote">that is pretty big, probably cuase the cost of the pistons for that size bore might cost some cashish. NOt sure if that size is customer made but more than likely.</TD></TR></TABLE>
actually only like 30 bucks more for 86mm pistons vs. like a 84mm...i am personally goin w/ 84mm right now in case something happens to the block and i'd have to rebore...just kinda nice to have a little leway...if i was loaded though, i'd be drivin around at 86mm....bore size that is
Old Oct 9, 2003 | 04:47 PM
boosted hybrid's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (junya16)
86mm here:
Block specs are gsr block, GE sleeved, custom 13.5:1 86mm Arias pistons, eagle rods, balanced and blueprinted. Looking for 230whp pre-itb's. BTW, the pistons were only 50.00 more than off the shelf through Arias. The intake/exhaust reliefs are pretty deep as well.
Old Oct 9, 2003 | 04:59 PM
Stein's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (boosted hybrid)
Wow, what kind of displacement is that?
Old Oct 9, 2003 | 06:01 PM
MackSpeed-616's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (Stein)
86mm bore
Old Oct 9, 2003 | 06:10 PM
PURPLETERROR aka BIGMATT's Avatar
fawking sic
Old Oct 9, 2003 | 06:51 PM
junya16's Avatar
Default Re: (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">fawking sic</TD></TR></TABLE>
my thoughts exactly
Old Oct 9, 2003 | 07:34 PM
RS_H22's Avatar
Jerry's Jerry Built/IB motor runs 86mm and is daily driven...
86 x 89 = 2060cc which is a 2.1L
262 WHP
11.86
Full interior, Stock doors and fenders...
Makes me curious what a deck plate motor with a 95mm stroke would do...
2207cc... 2.2L B Series motor... that would be some niceness
Old Oct 9, 2003 | 09:15 PM
b19coupe's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (MackSpeed-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">86mm bore
Those pistons are too pretty for that block
J/K. Looks killer.
Old Oct 9, 2003 | 09:22 PM
T4eg's Avatar
it doesnt leave much room for repairs, but it would be fine for all motor.
big displacement rules
Old Oct 10, 2003 | 03:17 AM
JunIntegra's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (BlueHatch00)
thats feakin sick! someone on the forums said 86mm should only be done for race use. besides the fact there is little room to rebore, why would that be true?? what about 85.5?
Old Oct 10, 2003 | 06:46 AM
dfoxengr's Avatar
look at the motor in my sig, and sweat it, lol
talk about 86x95 well here it is.
Old Oct 10, 2003 | 10:21 AM
Mr Hammond's Avatar
a/k/a Jomo
86mm pistons won't cost that much more. It is possible to run an 87mm bore. Granted sleeves do start getting pretty thin. Larger bore you go the harder it is to seal. That's one of the main reasons people don't go so high.
Old Oct 10, 2003 | 10:50 AM
slofu's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (Mr Milano)
from what i've read, the power gains from the 86mm bore are negligible over ~84mm bore, since most of the power from going 84mm over 81mm is made due to better breathing, not simply displacement, and if the headgasket won't seal (with the larger bore), you'll lose power and gain a big PITA. it seems that over 84mm, the head can't be configured to flow significantly better than it can at 84mm, so i'd stay around there, especially since, as others have noted, if something blows, you have room for an overbore.
Old Oct 10, 2003 | 11:48 AM
owen_the_soyboy's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (slofu)
/\/\/\/\ right on and well said.
And on the 2.2 liter setusp.... I would think the flow of the B series heads will be an issue with a 2.2 liter motor that has huge cams... although I want to see people make these creations!
86mm bore must be tough to seal a headgasket on with over 13:1 compression!!!!!!
Old Oct 10, 2003 | 11:57 AM
Enrikez's Avatar
Default Re: WHOA.. whos running 86MM pistons in there B-SERIES?? (owen_the_soyboy)
makes me wanna build up a side project motor..
damn nice guys!
Old Oct 10, 2003 | 12:52 PM
The 86mm bore will be fine even with high compression with sealing. There has been some GE sponsered cars running 85-86mm with 30psi, and no headgasket sealing issues. I will have to see how the set-up runs, but I am knocking on wood that everything will be fine. I had portflow do the cylinder head (b16a) and spotface the combustion chamber to 86mm, as well as port the head in the corresponding manner for a 86mm bore. I have thought through everything on this built up, I just hope that the reliability and #'s will speak for themselves in the future.
Old Oct 10, 2003 | 01:00 PM
from what you've READ?!? Get your nose outta the book and hit the track. I've seen over 20whp from 84-86. My dyno is proof, as wel as my time slips.
Old Oct 10, 2003 | 01:18 PM
If you wouldnt mind sharing, what did you make with your block? I'd love to see a dyno graph if at all possible.
BTW, checked out your site...is that SGT's dyno your car was strapped on?
Old Oct 10, 2003 | 01:48 PM
allmotorhatch's Avatar
You gained 20 whp from going from 84mm to a 86mm bore?
Old Oct 10, 2003 | 01:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">If you wouldnt mind sharing, what did you make with your block? I'd love to see a dyno graph if at all possible.
BTW, checked out your site...is that SGT's dyno your car was strapped on?</TD></TR></TABLE>
not sgt's dyno, just a local one we use.
the dyno sheet is under wraps for now.
i personally never built both a 84 and an 86mm engine. but i have been around plenty of 84-84.5's to know what those were making consistantly. And i know what mine makes. so yeah, there werent the same motors, but im making about 20whp more than those 84s ive been around. hell im making over 50hp more than some mild 2.0litre setups, there are alot of varying factors at that point. but nothing i do is that extreme, pretty simple and smart setup really.
Old Oct 10, 2003 | 01:59 PM
I actually believe you can gain 20whp from the step from 84mm to 86mm, its a proportional amount like going from 82mm to 84mm which produces a signficant amount. The larger area of the piston you can place a load on (work) the more torque produced, thus increasing horsepower.
Old Oct 10, 2003 | 02:00 PM
big tool's Avatar
Old Oct 10, 2003 | 02:11 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
ever heard of anybody using 87mm pistons...haha i have
