FS: Blitz SBC i-D & Blitz PowerMeter i-D ~!@
Old Oct 9, 2003 | 02:51 PM
t616
Guest
Posts: n/a
Default FS: Blitz SBC i-D & Blitz PowerMeter i-D ~!@
For sale Blitz SBC i-D electronic boost controller and Blitz PowerMeter i-D used for roughly 2 months and is in practically brand new condition. selling because im parting out my car.
SBC i-D Features:
Boost Unit – Can display boost in PSI, bar, KPA, and kg/cm2.
Four Channels – Has four different programmable boost settings.
Boost Gauge and Peak Hold – This boost controller has a built in boost gauge and peak hold that can be display in booth graph and digital form.
Boost Warning and Limiter – This is a safety function allows the user to set the amount of boost decrease in the event of any over boost. Warning in visual display and audible warning.
Scramble Boost – The scramble boost feature allows the user to set an increase or decrease in boost for a desired amount of time.
Manual or Automatic Boost Setting – The SBC i-D allows the user to set boost both in manual and automatic.
Automatic – Sets boost directly, just dial in desired boost setting.
Manual – Sets boost in ration, this setting will give maximum boost response. Recommended for high boost vehicles and large turbo.
Display – Can display up to 6 different reading, each reading can be display in both digital and graphical form. SBC i-D has the option to display 5 different vehicle readings. Power Meter i-D and SBC Optioonal harness are needed to display other readings. With Power Meter i-D connected, the SBC i-D can display SPEED and POWER. With SBC Optional Harness connected, the SBC i-D can display different electronic output from the ECU (ie. TPS, water temperature, oil pressure, A/F, injector pulse).
BOOST: Digital and Graphical
OPT1 / SPEED (Power Meter i-D required to display speed): Digital and Graphic Display
OPT2 / POWER (Power Meter i-D required to display power): Digital and Graphical Display
DATA 1 (SBC Optional harness required): Digital and Graphical Display
DATA 2 (SBC Optional harness required): Digital and Graphical Display
DATA 3 (SBC Optional harness required): Digital and Graphical Display
Record and Replay – SBC i-D has the ability to record and replay any information that was display on the SBC i-D. The SBC i-D can also replay information on the Power Meter and any of the optional data that is display. Replay can be fast forwarded and replayed in 2x and 5x.
Speed Map – The SBC i-D has the ability to control boost by speed (Power Meter i-D required). This function allows the user to fine tune the boost according to the speed of the vehicle. speed Map is set up by the different boost channels, the boost controller will switch channels automatically according to the speed of the vehicle, Speed is transfer from the Power Meter i-D by the infrared connection between the SBC i-D and Power Meter i-D.
Optional Display – The SBC i-D has the ability to display any electronic outputs from the ECU (SBC Optional Harness required Par #15053). It can read TPS, water temperature, oil pressure, injector pulse, A/F, and etc. The SBC Optional Harness will allow the SBC i-D to display up to 3 different readings, DATA 1~3. Any addition readings can be recorded and replayed.
PowerMeter i-D Features:
Power Meter i-D is a unique monitoring tool that measures both horsepower and speed. Power can be displayed in HP, PS, and kw. Speed is displayed in MPG and km/h. Both power and speed can be displayed in digital and graphical form. The Power Meter i-D also has a chassis dynamo function, which plots horspower to speed in a graph form.
The Power Meter i-D can time the following:
0-200m, 0-400, 0-1km
0-1/8mile, 0-1/4mile, 0-5/8mile
0-100km/h, 0-200km/h, 0-300km/h
0-50mph, 0-100mph, 0-200mph
This unit can also record and data log up to 5 different times.
<IMG SRC="http://www.we-todd-did-racing.com/wetoddimag
Old Oct 9, 2003 | 07:02 PM
t616
Guest
Posts: n/a
Default Re: FS: Blitz SBC i-D & Blitz PowerMeter i-D ~!@ (t616)
up
Old Oct 9, 2003 | 10:48 PM
t616
Guest
Posts: n/a
bump
Old Oct 10, 2003 | 10:25 AM
t616
Guest
Posts: n/a
buy me
Old Oct 10, 2003 | 01:47 PM
t616
Guest
Posts: n/a
buy buy buy
Old Oct 10, 2003 | 06:24 PM
t616
Guest
Posts: n/a
up up
Old Oct 10, 2003 | 06:27 PM
alpha's Avatar
How much for just the boost controller? Asking for a friend as I already have this controller..
Old Oct 10, 2003 | 11:34 PM
Soon_2b_evil's Avatar
Default Re: FS: Blitz SBC i-D & Blitz PowerMeter i-D ~!@ (0x64)
i think 500 for both right?
Old Oct 10, 2003 | 11:45 PM
t616
Guest
Posts: n/a
Default Re: FS: Blitz SBC i-D & Blitz PowerMeter i-D ~!@ (Soon_2b_evil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil &raquo;</TD></TR><TR><TD CLASS="quote">i think 500 for both right?</TD></TR></TABLE>
yes $500 for BOTH units and all the necessary hardware.
i guess i can do $350 shipped for just the boost controller alone, even tho the powermeter will be lonely
Old Oct 11, 2003 | 07:47 AM
alpha's Avatar
Buy them. I bet you will like this controller more than the Spec-II
Old Oct 11, 2003 | 08:32 AM
t616
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">
Buy them. I bet you will like this controller more than the Spec-II </TD></TR></TABLE>
listen to this guy he is a wise man buy buy buy !
Old Oct 11, 2003 | 08:35 AM
alpha's Avatar
Oh yeah. I don't know if you get PM's or not but I did PM you about the turbo
Old Oct 11, 2003 | 08:39 AM
alpha's Avatar
Your pictures are better since they are actually installed but here are some more to help your sale.
Old Oct 11, 2003 | 12:19 PM
Slick GS-R's Avatar
please check your email
Old Oct 11, 2003 | 03:36 PM
alpha's Avatar
I'm almost positive Soon_2b_evil is going to buy it when he gets home from work.
Old Oct 11, 2003 | 03:46 PM
Slick GS-R's Avatar
i have the money in hand for them right now!!!
please respond to my email!!!
Old Oct 11, 2003 | 03:51 PM
alpha's Avatar
Default Re: FS: Blitz SBC i-D & Blitz PowerMeter i-D ~!@ (Slick GS-R)
I dunno, lol. Soon_2b_evil replied first but ...
Old Oct 12, 2003 | 09:27 AM
t616
Guest
Posts: n/a
PM's have been relied to.
Old Oct 12, 2003 | 11:52 AM
Slick GS-R's Avatar
please check your PM/email once again
Old Oct 14, 2003 | 09:21 AM
Slick GS-R's Avatar
they're mine ... money is sent
Integra21
May 21, 2006 04:16 PM
Integra21
May 21, 2006 04:15 PM
alpha
Sep 26, 2005 09:09 AM
t616
Oct 14, 2003 09:23 AM
