^^^^^^^^Resurfacing aluminum flywheels?^^^^^^^^^
ok, i have a 9lb clutchmasters flywheel, and i think it needs to be resurfaced...can you resurface these? or will i have ot buy a new steel insert for it?
nevermind, got the answer...for future reference, its 100 $ for the steel insert for the flywheel from clutchmasters.
Chris, you may want to check around on that piece. I've seen the inserts for other applications for around $70. These were Fidanza, but I believe the two are identical anyway, so you can probably find the B-series piece for roughly that price.
well, the online shop im gonna be opening is gonnabe a dist for clutchmasters...sop ill just see about gettin it through that, thanks though :D
GRAVEDIGGER
May 8, 2006 02:58 PM
