all motor potenial of a b17
Old Oct 9, 2003 | 01:19 PM
importboi22's Avatar
Default all motor potenial of a b17
im puttin p30 pistons and a 2 layer hg on my b17 block b16 head combo i was wondering what kinda numbers i couuld pull w/ ctr cams and a nice intake / exhaust combo
Old Oct 9, 2003 | 01:24 PM
-KangaRod-'s Avatar
maybe 170 whp with good tuning. Its really just basically a B16 with a bit more stroke.
Old Oct 9, 2003 | 02:29 PM
Default Re: (-KangaRod-)
cool just what im looking for.... alright where can i get some pics of a p61 piston i was worried about valve clearence problems with ctr intake cam and 2 or 1 layer
Old Oct 9, 2003 | 02:31 PM
-KangaRod-'s Avatar
you'll be fine
Old Oct 9, 2003 | 04:13 PM
JD Milan's Avatar
even though it's a 1.7 the tq curve isn't that impressive. I would also stick with the oem 3 layer gasket, you literally gaining nothing with a 2 layer expect for potential future loss of your constructed gasket.
Old Oct 9, 2003 | 05:42 PM
Default Re: (JD Milan)
hrm really i figured .5 compression bump would be a good choice... grrrrr
Old Oct 9, 2003 | 08:18 PM
DA6GSR's Avatar
with my B17 block and B16 head I got 181 to the wheels. Had PnP, CTR cams, CTR pistons, 11.7-1 cr, 64 mm tb, and I think that was it. Well nitrous but with that i put down 229 whp.
Old Oct 9, 2003 | 10:38 PM
Default Re: (DA6GSR)
ls vtec is looking MUCH more tempting
Old Oct 9, 2003 | 10:42 PM
DA6GSR's Avatar
Default Re: (importboi22)
If you go LSVTEC why not just go CRVTEC for a better torque curve and little more lowend?
Old Oct 9, 2003 | 10:59 PM
ls bottom end 300 b20 bottom end 700.... :-P
Old Oct 9, 2003 | 11:01 PM
junya16's Avatar
i'll get you a full crvtec longblock for 600
Old Oct 9, 2003 | 11:08 PM
DA6GSR's Avatar
Yes but the power difference are noticeable. Especially if you are staying all motor you cant beat the 19 or 2.0 displacement.
Old Oct 17, 2003 | 01:23 PM
MoReRyCe's Avatar
Yeah go b20vtec.. much more fun... when u do that down goes sahar .. hehe
Old Oct 17, 2003 | 01:32 PM
-KangaRod-'s Avatar
high compression pistons for a b20 are expensive...
no OEM replacements.
Old Oct 17, 2003 | 02:05 PM
i know im looking out for b20z pistons but its only JSPEC GRRRRR
Old Oct 18, 2003 | 11:55 PM
PHiZ's Avatar
Here was an interesting setup I pulled from team-integra.net
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have your heart set on more displacement, the permutations and combinations are numerous. You just need to make sure the rods fit the piston and the crank, check that everything will fit in the deck height of the block you choose, and calculate the resultant displacement and rod ratio. As a popular recent example, many people try a B16A crank (77.4 mm) with LS rods (137 mm rod length) in a CRV block (84.5 mm bore when honed) to give 1736 cc, an oversquare layout, and a 1.77 rod ratio. You essentially build a 1.7 L Civic Type R Plus engine in your LS Integra that can rev like a bike.
-PHiZ
Old Dec 23, 2003 | 04:19 PM
Screamer's Avatar
Default Re: (PHiZ)
Would anyone have a b17 crank for sale???
Old Dec 23, 2003 | 06:23 PM
PHiZ's Avatar
Default Re: (Screamer)
I think katman does.
-PHiZ
Old Dec 23, 2003 | 09:22 PM
Dancing is Forbidden's Avatar
Default Re: (PHiZ)
Chad has a b17a with 1 layer and cams and it ran a 8.6 eighth mile.
Old Dec 25, 2003 | 06:38 AM
Screamer's Avatar
Default Re: (PHiZ)
where did you find this quote.... I woun't mind reading out on different setups like what he is writing about.
Old Dec 25, 2003 | 10:24 AM
Chigga1's Avatar
i think the B20 will definately produce better numbers then the LS block
thin about this!
a naturally asprirated b20B block will get 200HP easily on pump gas w/ over 150lbs-ft of pulling torque!
not bad IMO
Old Dec 25, 2003 | 10:25 AM
PHiZ's Avatar
Team-integra.net, tech section, "swapping parts for pwer"
******* excellent site. You have to register, but it's well worth it.
-PHiZ
Old Dec 25, 2003 | 10:41 AM
Screamer's Avatar
Default Re: (PHiZ)
thanks!!!
Old Dec 25, 2003 | 03:11 PM
JCushing's Avatar
its a toss up, on one hand you have an 84mm block with about 10:1 cr with a vtec head but you have small valve releifs
on the other you have a smaller 81mm block but you can put in some 12:1 oem pistons in there for super cheap and have the valve clearance on the piston and cr to run a big cam.
you have the potential to safely make more power with the ls block due to bigger cams/higher cr with slightly less tq or make less peak but more under the curve with 10:1 and R cams.
basically either one is a good choice but the lack of OEM (read as cheap) high cr pistons really hold the b20 back for the budget concious tuner.
Old Dec 25, 2003 | 04:25 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD Milan &raquo;</TD></TR><TR><TD CLASS="quote">even though it's a 1.7 the tq curve isn't that impressive. I would also stick with the oem 3 layer gasket, you literally gaining nothing with a 2 layer expect for potential future loss of your constructed gasket.</TD></TR></TABLE>
running a 1 layer now on my b17....stock bottomend toda c's....i estimate about 180ish to the wheels
