Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP?
Old Oct 9, 2003 | 12:53 PM
RTW DC2R's Avatar
Default Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP?
Just curious how it has held up for you. I have a HD pressure plate, but am looking for a streetable disk that can take an occassional 9500rpm.
Old Oct 9, 2003 | 01:04 PM
Big Phat R's Avatar
Default Re: Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP? (RTW DC2)
I'm using the Spoon unit (which was the same price as OEM here).
It uses a stock disk I think. They CLAIM to have stiffer springs on the PP. My impression is that it is true - but I could be wrong.
The clutch is holding up fine.
Old Oct 9, 2003 | 01:23 PM
HONDABROMANDUDE's Avatar
Default Re: Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP? (Big Phat R)
Just to let you know, I tried to use a stock ITR disc with an ACT HD pressure plate and the hub of the disc was too big, it hit the inside of the pressure plates face.
Old Oct 9, 2003 | 01:24 PM
DCtwoR's Avatar
Default Re: Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP? (itec311)
i dont think a stock clutch could handle it..thats just my .02
Old Oct 9, 2003 | 01:29 PM
euclid's Avatar
Default Re: Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP? (RedlineR 106)
look into an action disk, the full face kevlar would be perfect for your application i think.
Old Oct 9, 2003 | 01:41 PM
TyPe_R_GuY's Avatar
I am running everything stock, and i am making 201.3 whp with my R, well that much hp since June and the car has 45,xxx miles on it, and its still pretty strong
Old Oct 9, 2003 | 01:56 PM
Finland's Avatar
I ran the stock clutch for one year after boosting, it was adequate, but started slipping from the onslaught of boost. Held fine for "civilized" driving. I have had the CM stage 3 in for about 1.5 years, and am extremely happy with it, about 3 dozen drag-strip launches later, it still holds like when it was new. The pedal feel is close to stock as well. It's not laborious to drive in traffic either.
Old Oct 9, 2003 | 02:50 PM
MK Ultra's Avatar
Default Re: Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP? (euclid)
The ATS disc must be used with an ATS PP.
And ATS recommends against using their single plate carbon clutch for drag racing.
The combination of the ACT HD PP with their organic street disc is entirely streetable and capable of holding 260 lb-ft. of torque at the flywheel. IMO the car is easier to drive with the ACT HD/SS than it was with a stock clutch due to vastly improved pedal feel. The increase in pedal stiffness is noticable, but entirely reasonable and not difficult in the least to drive daily, even in heavy traffic. I've driven cars with OEM clutches that were stiffer than the HD/SS.
Old Oct 9, 2003 | 04:33 PM
Default Re: Anyone running a stock clutch disk(with any pressure plate) with 200+ WHP? (MK Ultra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">The ATS disc must be used with an ATS PP.
The combination of the ACT HD PP with their organic street disc is entirely streetable and capable of holding 260 lb-ft. of torque at the flywheel. IMO the car is easier to drive with the ACT HD/SS than it was with a stock clutch due to vastly improved pedal feel. The increase in pedal stiffness is noticable, but entirely reasonable and not difficult in the least to drive daily, even in heavy traffic. I've driven cars with OEM clutches that were stiffer than the HD/SS.</TD></TR></TABLE>
the.hamburglar
Oct 4, 2011 10:44 PM
specie
Apr 12, 2010 12:25 PM
B16Hatchcx
Jun 8, 2003 06:59 PM
rioninja
Aug 27, 2001 11:08 AM
SwiftTypeR
Jul 5, 2001 04:56 AM
