N/A and aftermarket rods
i head rods can stretch at high rpms....if your going to be reving past 8500rpm i would sugest some aftermarket rods or shotpeening your stock rods with acl bearing and arp rod bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd »</TD></TR><TR><TD CLASS="quote">i head rods can stretch at high rpms....if your going to be reving past 8500rpm i would sugest some aftermarket rods or shotpeening your stock rods with acl bearing and arp rod bolts</TD></TR></TABLE>
Not saying that it's impossible for them to stretch but I've been revving my motor to 10,000 on stock rods and experienced no problems.
Its not really that rods that stretch, its the rod bolts. Those are usually the weak point, especially LS,B20 rods. ARP rod bolts are a good investment are are cheap insurance. Stock rods are fine for most NA applications. With aftermarket rods, you usually have to run aftermarket pistons. If you use stock pistons, you have to modify them to adapt them to use locks. I believe Rocket has something that does this.
Dammit_Dan_954
Nov 30, 2003 11:18 AM
GOLDBERG
Oct 12, 2003 09:52 AM
