How often do you change the fuel filter?
Old Oct 9, 2003 | 11:08 AM
4505's Avatar
Default How often do you change the fuel filter?
Old Oct 9, 2003 | 11:11 AM
B2FiNiTY's Avatar
Default Re: How often do you change the fuel filter? (4505)
Every 30k
TypeR 01 886's Avatar
Well Im at 40x miles now and I was told to change it. Will this improve the cars performance. Just wondering.... but I think Im going to have it done this weekend. its like 70 bucks!
Old Oct 9, 2003 | 11:14 AM
GokuSSJ4's Avatar
Default Re: How often do you change the fuel filter? (TypeR 01 886)
i need to change mine , i wonder if i can fit an ITR filter on my EK
RTW DC2R's Avatar
$70?? u need to give Len a call, or just go to autozone and get a filter from there.
If you car has any hesitation or stumbles during the rpm range, a fuel filter may help that, assuming your current filter is causing the fuel delivery problem. Other than that you probably wont notice a difference.
Ferrell's Avatar
changed mine at about 40K
b18cu's Avatar
whats a good fuel filter? oem right...?
Old Oct 9, 2003 | 11:16 AM
00MRSi's Avatar
Like Dennis said, every 30k it's recommended. $70?? You gonna have the dealer rip you off? The filter costs about $20, maybe less and it's not hard to do. Do it yourself or have a friend help you.
I don't think you'll notice a difference in "performance". Car might feel smoother :shrugs: Using good premium fuel is important also.
00MRSi's Avatar
Default Re: How often do you change the fuel filter? (00MRSi)
Go to your local Acura dealer and pick up the filter.
Old Oct 9, 2003 | 11:17 AM
B2FiNiTY's Avatar
Default Re: How often do you change the fuel filter? (b18cu)
OEM
Old Oct 9, 2003 | 12:14 PM
dk127's Avatar
Hmm, I've never changed mine, and I'm at about 33k...
Now, I haven't seen the engine bay in a month, and I don't have a helms with me, but correct me if I'm wrong, the fuel filter is located on the firewall in the engine bay right? Almost in the middle...
Old Oct 9, 2003 | 12:16 PM
RTW DC2R's Avatar
yup...and there is a fuel line that runs to the fuel rail. cant miss it.
Old Oct 9, 2003 | 12:17 PM
Opie's Avatar
Default Re: (dk127)
I just replaced mine @ 30k miles with one from NAPA.
No problems here.. Just that i get 180 miles to a tank..
BTW--> Open the gas cap before removing the filter, makes the removal of the old one a lil less messy(I guess it releases some built up pressure, I learned from my mistake on my crx gas every where)
Old Oct 9, 2003 | 12:30 PM
euclid's Avatar
Default Re: (opie112)
oem, non-discounted is defintaley like 20$.
Old Oct 9, 2003 | 12:32 PM
yoshi234's Avatar
I shoot brides
@ 99km and haven't changed yet
yshi - whose had a new one sitting in his garge fo cupil yrs now
I would replace mine but I dont want to fugg with any gas related items on my car. My last integra was lost to flames and I was injured. I am petrefied to mess with any fueld related items on the car now
I wish it was as easy as replacing the air filter
Old Oct 9, 2003 | 12:37 PM
MissMyHonda's Avatar
hrmmm I should do this, maybe it'll fix the whole car stalling when it's cold issue...
Old Oct 9, 2003 | 12:51 PM
euclid's Avatar
Default Re: (JoesTypeS)
just remember to use a flare-nut wrench instead of an open ended which may strip the bolts... same for brake lines.
Old Oct 9, 2003 | 01:48 PM
00MRSi's Avatar
Default Re: (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">just remember to use a flare-nut wrench instead of an open ended which may strip the bolts... same for brake lines.</TD></TR></TABLE>
Great tip. Also Opie had a great tip. Take off your gas cap to bleed some of that excess pressure. You don't want gasoline flying everywhere..
Old Oct 9, 2003 | 02:36 PM
Bbasso's Avatar
Oh yeah one of the many things I have forgotton to do and I just pasted the 42,500 mark. I like to change it every 10k to be on the safe side.
Old Oct 9, 2003 | 02:44 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (Bbasso)
Did you guys notice a change in fuel economy after changing the filter?
Old Oct 9, 2003 | 02:52 PM
SoCal ITR's Avatar
Default Re: (FrostyDC4)
I thought the fuel filter never needed to be changed?
Old Oct 9, 2003 | 02:58 PM
Cheap Bastard's Avatar
New User
Default Re: (SoCal ITR)
i thought it was every 100k miles.
Old Oct 9, 2003 | 03:00 PM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">I thought the fuel filter never needed to be changed?</TD></TR></TABLE>
some people get away with it for a while. My civic has 245k miles and original owner never changed it Car started jerking and dying randomly because no gas getting to motor until i changed it
Old Oct 9, 2003 | 06:27 PM
97SpecR's Avatar
Im a Honda Tech and we do not change fuel filter at my dealership cuz they are life time now. From 95 and up. So you should not have to replace it unless you get water in your tank. If you do replace it, get one from Honda. ITR and a civic fuel filter are the same thing( 96 and up )
