Rsx springs in a o3 si?
I was wondering if i would be able to use a set of tein springs from a rsx in my si . The reason i ask this is because the spring rate is almost three times as much for the rsx than it is for the si.
SI: front157 Rear : 291
RSX:Front:307 Rear:492
Much higher on the rsx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapanExpress »</TD></TR><TR><TD CLASS="quote">I think someone tried this before, and it lowered a little in the front, and raised the rear.</TD></TR></TABLE>
That was Suk02Si (not sure if he's on here or not...). But he was just using stock
RSX springs, not the tein RSX springs. You could always give it a shot, drive
carefully, then sell them if it doesn't feel/look right. Or just buy a set that's made
for the Si.
for the Si.
how about Stock: 248 front 440 rear
for the EP instead of that real soft 150 something......EDIT crap missed the part about tein i guess....that is WAYYY soft like you said...
Modified by 1abSi at 12:28 PM 10/10/2003
Modified by 1abSi at 2:06 PM 10/10/2003
