1.5 DOHC
Wondering if anyone knows off hand of any complications associated with putting a 88-89 Integra head on a 90 Civic DX block? I will convert to MPFI, I had a DX block lying around and a very rudementary test fit concluded that it does at least fit on the block, turned the crank over (with timing belt installed) didn't hear any collisions, the 1.5 oil return hole is slightly smaller the the SI one but it appears if you use the SI head gasket there would be very minimal restriction with the oil draining from the head. Can anyone think of any compression problems?
civicracer1993
17
Nov 18, 2003 05:20 PM
