new fluidyne, is if ****** up??
Old Oct 9, 2003 | 09:35 AM
oMek's Avatar
Default new fluidyne, is if ****** up??
i just got ther radiator and on the bottom one of the square mount points for the fan is like crooked and welded kinda weard. does anyone else have a radiator like this??? or should i send mine back to get fixed???
Old Oct 9, 2003 | 09:36 AM
P1mpSlap's Avatar
call them up and ask them what's the deal.
Old Oct 9, 2003 | 09:41 AM
oMek's Avatar
Default Re: (P1mpSlap)
i got it off a HT member. its new never bin used, but i dont know if they will honor a warrenty
Old Oct 9, 2003 | 09:44 AM
P1mpSlap's Avatar
call and find out. For all it maybe worth, that little bend might be to fit in a tight place or something.
:just a thought:
Old Oct 9, 2003 | 09:50 AM
oMek's Avatar
this is what im talking about
Old Oct 9, 2003 | 10:00 AM
P1mpSlap's Avatar
dude I dont know how else that thing could've got there unless someone ment to weld that there. The weld is almost perfect.
I'm sure that piece serves some purpose or isn't used at all.
oMek's Avatar
Default Re: (omekone)
anyone else have this radiator for a 94+ integra? does it have this on it?
Old Oct 9, 2003 | 10:01 AM
oMek's Avatar
ya thats what i figure. no one would weld it like that unless it needed to be. if they did they musta bin smoking crack
Old Oct 9, 2003 | 10:09 AM
B2FiNiTY's Avatar
You should be ok. Never seen one in person so I can't tell you if that's a defect or not.
Old Oct 9, 2003 | 12:12 PM
oMek's Avatar
Default Re: (B2FiNiTY)
ok well i just installed the radiator and it seems to be in the right place. my stock radiator fan SUX the bottom does not have screw holes there are like litttle clips on the stock radiator. i got it ghetto rigged right now. i guess ill buy a slim line fan and put it on at a later time
thanks for the help guys
Old Oct 9, 2003 | 04:39 PM
dwolsten's Avatar
That mount is correct; my Fluidyne has it as well. However, my fan bolts to it. My fan is from a '94.
Old Oct 10, 2003 | 10:10 AM
roadrunner's Avatar
That's by design. I have a Fluidyne on my '97 GSR and the lower fan mounts are exactly like that. The OEM fan (tranmission side) bolts up to those tabs, though not without a little finessing to line it up.
lsvtecEM1
Mar 19, 2012 05:18 AM
lsvtecEM1
Mar 18, 2012 10:38 AM
TOO MUCH TORQUE
Apr 4, 2011 05:10 PM
SuicideSlide
Nov 25, 2004 05:11 PM
nicksweetlude
Feb 26, 2002 03:27 PM
