i got some suspension problems.....
Old Aug 29, 2001 | 05:43 PM
GSRfoedoe's Avatar
Default i got some suspension problems.....
everytime i push on the brakes gently i hear this tumbling noise like an axle is loose or something. its not a clicking noise but more of a tumbling. if i hit the brakes hard its no noise. its not clicking when i turn so im sure its not the cv axle. any ideals...
Old Aug 29, 2001 | 06:43 PM
BreakStuff's Avatar
New User
Default Re: i got some suspension problems..... (GSRfoedoe)
Does the frequency of the noise match the tire revolutions?
What I mean, does the noise get slower when speed decreases and vice versa?
Old Aug 30, 2001 | 07:14 AM
GSRfoedoe's Avatar
Default Re: i got some suspension problems..... (BreakStuff)
yeah it does. i just put that axle in, i dont understand. i put both axles in at the same time. its coming from the driver's side. its just when i have the brakes half way down or not all the way. i was thinkin it was the axle but it happen to my last axle too.
Old Aug 31, 2001 | 04:52 AM
92sleepR's Avatar
New User
Check that the inboard axle joints are FULLY seated. They can pop loose. Also, check all the suspension mounting bolts. I recently had a noise that i was sure was the axles but it turned out that the bolts holding the radius arm bushing bracket were loose. I live in Washington DC and we have the shittiest roads outside of a third world country. At least once a month i have to crawl under my car to asses the damage and tighten everything up. I should sue the ******* city for all the damage it does to my car!.
Mike
Old Aug 31, 2001 | 06:15 AM
GSRfoedoe's Avatar
Default Re: i got some suspension problems..... (92sleepR)
thanx man...ill check the bolts. are u talkin about the inner axle joints or u talkin about something else. hey maybe i should sue too. atlanta has some shitty roads and shittier drivers.
Old Aug 31, 2001 | 02:51 PM
rioninja's Avatar
Also, are you sure your rotors arent warped?
Old Sep 1, 2001 | 07:15 AM
8Ball's Avatar
check the wheel bearing?
F20B_accord
Oct 3, 2010 06:43 PM
the_dxB16
Nov 10, 2008 01:29 PM
TomFin
Suspension & Brakes
Mar 6, 2006 11:20 AM
B18C-RnVA
Feb 25, 2002 08:30 PM
