Driveshaft oil seal help
Old Oct 8, 2003 | 07:13 PM
CanB16's Avatar
Default Driveshaft oil seal help
Hello everyone, Im new here, seems to be a nice site.
All sucking up aside, I need to change a transmisson oil seal (the one the driveshaft goes through). Tranny is a JDM Y1 = can I use a USDM B16 (del sol) or a B18A (90-91 teg) oil seal? Or maybe all B-series are the same?
Thank you
Old Oct 9, 2003 | 04:22 PM
CanB16's Avatar
Default Re: Driveshaft oil seal help (CanB16)
bump
Old Oct 9, 2003 | 04:34 PM
fourthgenhatchB17's Avatar
I had to replace that seal too, but it was the one on the end of the halfshaft. What i did was pry the old seal out and take it to the autoparts store. They used the little part number thats imprinted on the side and got me the correct one. The part number is very very small but its there. I assume all the B series ones would/should be the same, but i would go with the 90-91 teggy seal if u dont feel like taking the old one in.
Old Oct 9, 2003 | 04:53 PM
Outsane's Avatar
Default Re: Driveshaft oil seal help (fourthgenhatchB17)
IF you dont know already..
Take off the fill bolt first...just incase you can't get it off after you have pulled the drain bolt...
Old Oct 9, 2003 | 07:05 PM
Default Re: Driveshaft oil seal help (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">IF you dont know already..
HUh...no one was even talking about draining the oil. But anyways, those fill plugs can be a biotch to get off and in case YOU dont know, u can fill it through the speedo gear hole too. Its a bit easier...
Old Oct 10, 2003 | 10:01 AM
FR-MOB: ThE bEe GuY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
HUh...no one was even talking about draining the oil. But anyways, those fill plugs can be a biotch to get off and in case YOU dont know, u can fill it through the speedo gear hole too. Its a bit easier...</TD></TR></TABLE>
I think he means take out the bolt so that when he tries to take out the seal, the seal wont be stuck in there because of the sucking...is that what ur trying to say? If not then to me
Old Oct 10, 2003 | 10:23 AM
Outsane's Avatar
Default Re: Driveshaft oil seal help (ThE bEe GuY)
I actually meant to take out the fill plug first, because a friend of mine could not getit off after the drain plug was pullled..pain in the ***...
Old Oct 11, 2003 | 02:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY &raquo;</TD></TR><TR><TD CLASS="quote">
I think he means take out the bolt so that when he tries to take out the seal, the seal wont be stuck in there because of the sucking...is that what ur trying to say? If not then to me</TD></TR></TABLE>
Judging by his second post, i dont think thats what he meant. So yes to you, haha.
And about the sucking thing you are talking about, i think i know what ur tryin to say. But since the seal will need to be removed, the axle will need to be pulled out beforehand, so no "sucking" action would take place, even if it exists (which i doubt).
Old Oct 11, 2003 | 07:39 PM
CanB16's Avatar
Thanks for the info everyone. The fill bolt is fine, just checked the oil level. So you can fill with oil through the speedo housing? never thought of that before... thanks again.
Old Oct 12, 2003 | 12:04 PM
Never tryed through the housing itself, but u pull out the speedo gear then fill through the hole in the tranny. Remove the speedo cable, then the 1 10mm bolt, then pull the speedo gear out.
delsolo95
Feb 19, 2010 09:50 AM
invisible
May 19, 2007 03:25 AM
93hatchin
Jul 25, 2005 04:49 AM
danteisme
Jun 1, 2005 05:31 PM
jansenrw
May 18, 2004 12:05 AM
