GSR block/b16 head?
Old Oct 8, 2003 | 07:04 PM
Mark's Avatar
*Bounty Hunter*
Default GSR block/b16 head?
I havent decided yet, but I think I want to go with a B16 head on my GSR block. This, with CTR cams, and ITR pistons should make for a good compression and more power than my stock GSR head. Also, the valvetrain can rev higher safely, and the head flows better...
Any opinions? Also, what would I have to change besides pistons/rods to adapt the head safely?
Old Oct 8, 2003 | 07:06 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: GSR block/b16 head? (94BlackCivicEX)
Yeah, don't waste your money.
Old Oct 8, 2003 | 07:12 PM
Mark's Avatar
*Bounty Hunter*
Default Re: GSR block/b16 head? (Mr Milano)
I should or i Shouldnt?
Old Oct 8, 2003 | 08:36 PM
Mark's Avatar
*Bounty Hunter*
Should i just build the GSR head? Any suggestions?
Old Oct 8, 2003 | 08:56 PM
BolivianDc2's Avatar
build the GSR head, it will give you more compression, the valvetrain determines whether or not it could handle high revs, and they both flow pretty much the same. You must have got the wrong info somewhere.
The only disadvantage to the GSR head is there is no $200 intake manifold you could just strap on like the ITR manifold on pr3 heads. (cheapest being skunk2 for around 350 after all the extras you have to buy)
If you want to rev higher you could have to get at least ARP rod bolts for your stock rods.
Old Oct 8, 2003 | 10:45 PM
Mark's Avatar
*Bounty Hunter*
Default Re: GSR block/b16 head? (Bolivianstrtwpn)
well i figure ill do all the bolts on now, and rip apart the block over winter. yay
Old Oct 9, 2003 | 01:09 PM
AzG35's Avatar
If you already have a GSR head, then build that. Although, you could sell either for a decent amount and keep the money to build either.
408EJ1
16
Jan 8, 2014 03:23 PM
bullet647
Jul 15, 2007 09:19 PM
racingfan
13
Sep 6, 2005 02:09 AM
BI8B
Sep 11, 2003 08:38 AM
Tyson Ballou
Dec 26, 2001 06:17 PM
