Will 215/45/16 Azenis rub on an Integra
I recently got some 16x7 wheels with a 45 offset. My Integra is lowered 2" in the front and 1.65" in the back. If I run 215/45/16 Azenis, will the tires rub? Also does anyone know of a comparable tire that will get a little more tread life than the Azenis. Thanks for any advice.
I have that same tire size and brand on Kosei K-1, 16x7.5 +43 offset. I also have GC/Koni setup with 400lb and 350lb rear springs and car is lowered about 1 3/4 - 2 inches. The fronts have never touched any part of the car; the rear just touched the inside fender lip on track days only when the supsension sees more travel and only at the very top of the wheel well. I just took off that rubber strip and this may give the clearane so it won't touch at all. I will find out this weekend at Gingerman.
