Condensor fan wont come on. . . relay problem?
It stopped working but when I connect it to the battery it works. I checked the wiring and there is no power going to the fan. Fuses are ok. Where is the relay on this @!$#% thing? Anything else to check?
pull the harness off the thermoswitch and use a paper clip or small wire to jump it.
If it turns on, your thermoswitch is bad.
If it doesn't, your wiring is messed up.
97civicowner
34
Aug 27, 2018 06:09 PM
EFOwNzALL
Jul 29, 2008 10:15 PM
