will rc injectors for an obd1 92-96 prelude fit an obd1 gsr???
Old Oct 8, 2003 | 02:00 PM
junya16's Avatar
Default will rc injectors for an obd1 92-96 prelude fit an obd1 gsr???
any modifications needed or will they clip right in??
Old Oct 8, 2003 | 02:13 PM
HONDABROMANDUDE's Avatar
Default Re: will rc injectors for an obd1 92-96 prelude fit an obd1 gsr??? (junya16)
The clips should be fine but if they are made for a 92-96 prelude they will be peak and hold and all gsr's used saturated injectors.
Old Oct 8, 2003 | 03:54 PM
junya16's Avatar
Default Re: will rc injectors for an obd1 92-96 prelude fit an obd1 gsr??? (itec311)
well i'm using the stock fuel injectors from my 92 ls....are those still saturated or peak/hold???
Old Oct 8, 2003 | 10:46 PM
RedZone's Avatar
You will need to use the resistor box from the prelude to use the prelude injectors on a OBDI integra or civic.
Old Oct 8, 2003 | 11:01 PM
junya16's Avatar
Default Re: will rc injectors for an obd1 92-96 prelude fit an obd1 gsr??? (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">You will need to use the resistor box from the prelude to use the prelude injectors on a OBDI integra or civic.</TD></TR></TABLE>
thanks for clearin that up
Old Oct 9, 2003 | 01:11 PM
AzG35's Avatar
Yes, this is correct.
zman
Jan 6, 2006 11:45 AM
riceball777
Apr 27, 2004 10:21 PM
DelsolVtec18
Nov 25, 2003 07:23 AM
