88 crx hf suspension
Old Oct 8, 2003 | 10:25 AM
ironchef25's Avatar
Default 88 crx hf suspension
whats the best way replacing my shocks.
kyb? tokio? mcpherson or other?
Modified by ironchef25 at 11:54 AM 10/8/2003
Old Oct 9, 2003 | 06:49 AM
ironchef25's Avatar
Default Re: 88 crx hf suspension (ironchef25)
(BUMP) SO ANY BODY HAVE ANY IDEA?
Old Oct 9, 2003 | 06:52 AM
1st-hybrid's Avatar
Do you want to know what would be the best or the best way to replace them?
Try to clear up ypur question a bit
I have tokico blues with GC's on my hf and it rides great.
Old Oct 9, 2003 | 10:05 AM
ironchef25's Avatar
well i was thingking of putting performance shocks and spring to make the ride a little better and perform better. so i guess is it would be like and all and all question.
Old Oct 13, 2003 | 07:53 AM
ironchef25's Avatar
bump! so anyone have any idea whats the best way to go. my friend told me about tokio gas shocks while the other told me to go with kyb. not sure which one would make the best handling suspension shocks
Old Oct 13, 2003 | 08:54 AM
HumanResource's Avatar
88 HF rear suspension differs from 89-91
KYB doesn't make rear shocks for the 88 HF
Go with Tokico Blues and Eibach proKit's-Not too low, not too firm, just sporty
Old Oct 13, 2003 | 09:03 AM
EL Vap133's Avatar
Bilstein....
Old Oct 13, 2003 | 09:17 AM
ironchef25's Avatar
Default Re: 88 crx hf suspension (HumanResource)
tokiko blues,hmmm sounds good. do they make front and back. and whats the best lowering spring to match that? i just got my crx two weeks ago and it was already lowered. it seems like the previous owner. went the ghetto way of lowering the crx. spring was cut down. ouch. and also. coils or spring?
Old Oct 13, 2003 | 10:17 AM
88crx Osaka's Avatar
I have KYBs GR2 all around on my 88 crx (had to change rear lower control arm with 89-91 crx/civic. Front struts im using 89 accord(more travel) Thats with Skunk2s coilovers and now i did red bushings all around including rear trailing arm bushing. I didnt drive the car yet. Next week i will drive it, should be big differance. I post next week how is the suspension.
Guys who did rear trailing arm bushings. It was hard to replace it but worth it. Now i kick the rear tire and it doesnt move at all before it had play in it.
So if you mess with suspension replace all the bushings with poly...
Old Oct 13, 2003 | 12:32 PM
Todd00's Avatar
I said I don't want a title!
Check my sig. I have some Konis Sports for sale (cheap) that fit the 88 cars.
Otherwise, Tokicos are decent shocks and decently priced.
Old Oct 14, 2003 | 10:46 AM
temp's Avatar
just give me your rear lower control arms, and go get some 89-91 ones, you dont need those silly 88 rear lower control arms
Old Oct 14, 2003 | 11:32 AM
EL Vap133's Avatar
Default Re: 88 crx hf suspension (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">just give me your rear lower control arms, and go get some 89-91 ones, you dont need those silly 88 rear lower control arms</TD></TR></TABLE>
hahahaha! Why don't you trade him?
Old Oct 14, 2003 | 11:34 AM
temp's Avatar
Default Re: 88 crx hf suspension (EVIL_Vap133)
because i have KYB shocks on my suspension and he has stock shocks....not a fair trade to me.....
Old Oct 14, 2003 | 11:35 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">because i have KYB shocks on my suspension and he has stock shocks....not a fair trade to me..... </TD></TR></TABLE>
I'm talking about the control arms....
Old Oct 14, 2003 | 11:38 AM
temp's Avatar
i know but then i would have to go buy rear shocks, and i dont want to do that right now, i want those LCA's so i can run some imported tein HA's or HR's
Old Oct 14, 2003 | 12:04 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">i know but then i would have to go buy rear shocks, and i dont want to do that right now, i want those LCA's so i can run some imported tein HA's or HR's</TD></TR></TABLE>
They are only about $55/piece brand new form the dealership and even cheaper in the yard. Just go buy some.
Old Oct 14, 2003 | 12:05 PM
temp's Avatar
Default Re: 88 crx hf suspension (Todd00)
i know....but i am a cheap ******......last time i was at pick n' pull i was going to grab some but i ran out of time from lunch, i will be going to pick n' pull soon again and i will grab some next time
Old Oct 14, 2003 | 12:48 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">i know....but i am a cheap ******......last time i was at pick n' pull i was going to grab some but i ran out of time from lunch, i will be going to pick n' pull soon again and i will grab some next time</TD></TR></TABLE>
hahaha, well that's your problem!
Old Oct 14, 2003 | 01:25 PM
temp's Avatar
arrrggghhhhh lol ......well hopefully i can solve that tranny leak problem and then i will work on the suspension issues.....
Old Oct 14, 2003 | 02:14 PM
Outsane's Avatar
You can buy any companies rear shocks for you car..
You just have to order integra type R shocks..
I am runnin bilstien shocks, on my 88 CRX.
88 fronts, type R rear
and I get them at dealer price..so its not so bad.
Old Oct 14, 2003 | 02:28 PM
temp's Avatar
Default Re: 88 crx hf suspension (Outsane)
now my question to you is wouldnt the type r dampers be too stiff as they are made for a car with a lot more weight?
Old Oct 14, 2003 | 03:05 PM
EL Vap133's Avatar
Not really since it's the rear of the car only....
Old Oct 14, 2003 | 03:08 PM
temp's Avatar
but it is still made for a car that weighs more so in theory the internals of the damper should reflect this right?
Old Oct 14, 2003 | 03:11 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">but it is still made for a car that weighs more so in theory the internals of the damper should reflect this right?</TD></TR></TABLE>
According to Bilstein no, I went to a Bilstein seminar....
Old Oct 14, 2003 | 03:33 PM
Was gone during the whole 89 Accord front shock debate.
Are the 89 Bilstein Accord Front shocks shorter as well?
