problem with mpfi swap
Old Oct 8, 2003 | 10:01 AM
tgreaves's Avatar
Default problem with mpfi swap
I am in the process of doing the mpfi swap on my dx crx.. I am trying to put the dx dizzy plug on to the si dizzy.. The problem I am having is that 7 wires total.. I know 2 of them are for the mpfi stuff but the other 5 go to the dx harness.. I know I match up the colors of the wires when putting the plug on but there are 2 white wires that dont have a stripe.. Anyone know which one goes to what wire from the plug..
Old Oct 8, 2003 | 10:14 AM
xvracing's Avatar
Default Re: problem with mpfi swap (tgreaves)
one of them is slightly bigger than the other, but its really hard to tell. Just hook them up the best you can and if you don't get spark, just swich them.
Old Oct 8, 2003 | 10:17 AM
tgreaves's Avatar
Default Re: problem with mpfi swap (xvracing)
Ahhh... Ill try to see if I can tell what one is bigger.. Is that all that will happen if they are hooked up wrong is no spark..
Old Oct 8, 2003 | 10:56 AM
pokemon's Avatar
yes
Old Oct 12, 2003 | 01:56 PM
Grease Monkey's Avatar
Default Re: (pokemon)
Same thing happened to me yesterday. Had the two white wires the wrong way and didnt get spark. Once I swapped them the car started right up. The only problem now is the CEL. My ecu doesnt have a L.E.D on it to check the code.
Old Oct 12, 2003 | 06:59 PM
youngwon22's Avatar
Default Re: (Grease Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me yesterday. Had the two white wires the wrong way and didnt get spark. Once I swapped them the car started right up. The only problem now is the CEL. My ecu doesnt have a L.E.D on it to check the code. </TD></TR></TABLE>
new in the 2nr life how do you check the codes?
Old Oct 12, 2003 | 07:02 PM
Default Re: (youngwon22)
On the ecu there is a red L.E.D. basically it will flash and give you the code which will explain your problem. I on the other hand, need to solder a new L.E.D since my ecu mysteriously doesnt have it.
Old Oct 12, 2003 | 08:20 PM
Caleb V's Avatar
The two extra wires are a Bl/YW and BL/GN wire for the Cylinder position sensor that the DX never had.
Slotz_HB
Sep 18, 2009 01:56 PM
slowslow
Mar 22, 2007 02:56 PM
SomeDude56
Sep 21, 2005 10:32 PM
RaysBoomBoomLude
Aug 27, 2005 01:10 PM
pokemon
Mar 12, 2003 09:31 PM
