1990 Accord shakes at Idle
Old Oct 8, 2003 | 07:39 AM
jimby452's Avatar
Default 1990 Accord shakes at Idle
I have a 1990 Accord 5 spd. When I am sitting at an idle the whole car starts to vibrate. If I step on the gas and increase the RPM's to 1000, the vibration stops. The car runs fine once I get above the idle speed. Anyone have any ideas as to what could be causing my problem. Thanks
Jim
Old Oct 8, 2003 | 08:16 AM
TomSlick's Avatar
Default Re: 1990 Accord shakes at Idle (jimby452)
Sounds like your motor mounts. The front mount is probably the worst offender, but you'll want to check the others too. Hope it's not the back, 'cause that one's more difficult to replace and is more expensive. Just replaced my front mount ('90 with 4-sp auto) and it made a world of difference.
Old Oct 8, 2003 | 08:33 AM
FatJoe's Avatar
Default Re: 1990 Accord shakes at Idle (TomSlick)
whats your car idling at?
Old Oct 8, 2003 | 12:01 PM
jimby452's Avatar
Default Re: 1990 Accord shakes at Idle (H22Accord90DX)
Thanks for the reply. I am reading the tach that is in the instrument panel in the car. I have it running at about 800 RPM's. I'll check the motor mounts.
Old Oct 8, 2003 | 12:23 PM
iam7head's Avatar
check the mount, rev it and shift and have a friend see how bad the motor rock
Old Oct 10, 2003 | 06:06 AM
jimby452's Avatar
How did you determine that the mount was bad? Does the rubber get hard so that the engine vibrations are not buffered by the rubber bushings anymore? If I take out one mount at a time, start the car and let it idle, will that help me find the bad one?
Old Oct 10, 2003 | 09:42 AM
4genaccordfreak's Avatar
hmmm i'm havin the same problem with my 90'
so probably is a mount bushing that is solid!
emmaturecb7
Jan 10, 2008 04:56 PM
m1ndless
Jul 30, 2007 07:51 PM
HONCORD
Apr 12, 2006 10:01 PM
fever502
Jan 9, 2006 05:49 PM
