finally after 1.5 years of building a kit its done...here it is
Old Oct 7, 2003 | 10:06 PM
delslow94's Avatar
Default finally after 1.5 years of building a kit its done...here it is (56k itll be a while)
i know its nothing huge to you all but i just finished my turbo kit tonight. still a few problems to work out like how my iac now mysteriously throws a code but still works...but other than that its just nit pick stuff. well enough of me talking heres some pics.
a pic of me finishing up the the dp
o2 bung...hey im new to welding so dont give me too much hell for it
ok so i know its a lot of stuff...but im excited for it to work. the tech part is why would i throw an iac vavle code (code 14) even tho my iac works fine and holds a cold idle. i just have the light. anyone have an idea?
Old Oct 7, 2003 | 10:20 PM
SlippylesKB's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (delslow94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslow94 &raquo;</TD></TR><TR><TD CLASS="quote">
You have very girly hands.
Old Oct 7, 2003 | 10:23 PM
delslow94's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (SlippylesKB)
thanks scott....now to change the axle tomorrow...if the neighbors dont take the driveway up
Old Oct 7, 2003 | 10:51 PM
inspyral's Avatar
That's some blingin piping
Nice job on the DP too.
Old Oct 7, 2003 | 10:54 PM
Ri5e's Avatar
1.5 years... and I thought a couple months of downtime was bad...
nice setup btw
Old Oct 7, 2003 | 10:55 PM
NuclearB18B's Avatar
Default Re: (inspyral)
nice
Old Oct 8, 2003 | 04:29 AM
Too_Smooth's Avatar
Hey where did you get that valve to restrict the oil flow?
Oh and good luck with your setup!
Old Oct 8, 2003 | 04:31 AM
keebler65's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (Too_Smooth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Too_Smooth &raquo;</TD></TR><TR><TD CLASS="quote">Hey where did you get that valve to restrict the oil flow?
Oh and good luck with your setup! </TD></TR></TABLE>
thats just an oil pressure sensor if i'm not mistaken. the same one that was on the back of the block in its stock form.
Old Oct 8, 2003 | 04:36 AM
Overblown-Teg's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (keebler65)
YOU look just like J. Davis.. its scary
Old Oct 8, 2003 | 05:39 AM
SOFLSOL's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (Overblown-Teg)
Looks great. Great for more turbo sols.
Old Oct 8, 2003 | 08:13 AM
delslow94's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (SOFLSOL)
thanks for the reply guys yea its just the oil pressure sensor. i used the t fitting and mounted it up there because it was out of the way and so that i could see if i had a leak. works great tho...no problems with oil yet. a little dribble on the oil return but im sure a little teflon tape will fix it right up
Old Oct 8, 2003 | 09:53 AM
BoM's Avatar
BoM
nice job!
what size is that downpipe?
my setup is the same way, and its soo tight by the radiator.
Old Oct 8, 2003 | 10:53 AM
delslow94's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (BoM)
its a 2.5" dp that touches the fan so i wrapped it...hasnt melted yet
Old Oct 8, 2003 | 12:14 PM
bigwig's Avatar
Congrats. i think its amazing you stuck with it for that long. I hope my 2 month deadline doesnt turn into 2 years...
Old Oct 8, 2003 | 01:42 PM
delslow94's Avatar
Default Re: (bigwig)
thanks...goodluck yourself. just keep with it and wait to install till u know u have everything under the sun that u need along with extras...vaccum hose, t fittings, zip ties, etc.
Old Oct 8, 2003 | 03:31 PM
Eee Pee's Avatar
Default Re: (delslow94)
New to welding....
When you guys gonna bring it over?
Old Oct 8, 2003 | 03:41 PM
grndcont's Avatar
how do u like that ex manifold?, who's is it?
Old Oct 8, 2003 | 03:57 PM
espanol's Avatar
what plug wires are those?
Old Oct 8, 2003 | 05:20 PM
delslow94's Avatar
Default Re: finally after 1.5 years of building a kit its done...here it is (espanol)
the manifold is a max rev that has been jet coated. its a real nice piece but it puts the wastegate banjo bolt right up on the head so i am going to get an elbow for it. and yes those are apc wires....they work good especially when ur stock decided to get a short in them. cant beat em for 10 bucks until the new ones get here
wade
Welding / Fabrication
May 9, 2008 01:58 AM
TurboSI56
24
May 9, 2007 02:28 PM
si foo
Jun 8, 2004 03:00 PM
fast4w$
Oct 2, 2003 12:20 PM
bey
Nov 7, 2002 09:38 PM
