Bad things can happen if you don't check EVERYTHING!
Old Oct 7, 2003 | 08:50 PM
b19coupe's Avatar
Default Bad things can happen if you don't check EVERYTHING!
Put a motor together, and within 20 miles or so it developed a knock. Here is what I found when I tore it down:
In this photo you can see the cause of the problem-when the machine shop bored the block to 85mm, they did not go all the way down, they just bored the sleeves. There is just enough of a lip to catch the bottom of the piston skirt-note the arrow:
The other side of the bore (#3 BTW):
Here is a view from the bottom-the piston on the left of the picture is an IB Spec Wiseco (the pistons actually run in the motor), the skirt just hangs down even with the lip. The piston on the right is a JE from another motor, the skirt hangs down a good 3/8" below the lip.
Hope this does not happen to anybody else. You learn something new every day
Old Oct 7, 2003 | 08:55 PM
631 Teggy's Avatar
Default Re: Bad things can happen if you don't check EVERYTHING! (b19coupe)
Holy **** what ghetto *** machine shop did that?
Are they ganna repay you for parts?
Old Oct 7, 2003 | 10:05 PM
Drag R's Avatar
damn, that sucks man. the worst things always happen to you.....
nick
Old Oct 7, 2003 | 10:12 PM
RangerDan's Avatar
Default Re: Bad things can happen if you don't check EVERYTHING! (Drag R)
Ouchy. Man I feel your pain.
Good luck with the re-rebuild.
Old Oct 8, 2003 | 06:14 AM
psycho_civic's Avatar
what shop was this?
Old Oct 8, 2003 | 06:21 AM
b19coupe's Avatar
Default Re: (psycho_civic)
Block initially sleeved by Golden Eagle, bored to 85mm by Superior Machine in Anaheim, California.
Anaheim, not Fullerton-just looked at the receipt.
Modified by b19coupe at 11:15 AM 10/8/2003
Old Oct 8, 2003 | 07:03 AM
advanracing62's Avatar
Default Re: (b19coupe)
oh crap! that's jacked up... are they going to pay for that screw up?
Old Oct 8, 2003 | 08:43 AM
owen_the_soyboy's Avatar
oh man I feel your pain.
to find that out within 20 miles that there is that big a problem with your new setup.
Musta been a shock I bet and what a lot of work to go to in order to fix the problem.
man, what a PITA!
Old Oct 8, 2003 | 08:54 AM
GokuSSJ4's Avatar
Default Re: (advanracing62)
that sucks !! it just shows you that is good to always check your stuff after others have work on it.
Old Oct 8, 2003 | 09:06 AM
1_bad_EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Block initially sleeved by Golden Eagle, bored to 85mm by Superior Machine in Fullerton, California.</TD></TR></TABLE>
throw the block back at em'
at least show them that they fugged up.
see what they say.
AllMoToRB18c's Avatar
Default Re: (Spoon1)
i hope that machine shop pays for ur rebuild...if not that sux
Old Oct 8, 2003 | 10:38 AM
soakit's Avatar
Ive found that a great machine shop is in OC is called HAIL's(sp) its located right by where importbuilders were. they are very precise and delivery is quick. I'm suprised JEFF didnt turn you onto them.
Old Oct 8, 2003 | 10:58 AM
DevinW's Avatar
OUCH! Man, I hope they pay for the damages....good luck!
Old Oct 8, 2003 | 11:39 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Good luck man, I dont know how they could have done something like that.
Old Oct 8, 2003 | 11:46 AM
turbo*s2k's Avatar
Default Re: (v-attack)
So it was orginally sleeved by GE, and then you had it bored to 85mm by a machine shop? Why not have GE do the whole thing?
Old Oct 8, 2003 | 12:56 PM
b19coupe's Avatar
Well here is a surprise: the machine shop accepted ZERO responsibility.
As I expected. Their argument is that their responsibility ends with the cylinders. "The boring bar does not go down that far. That part of the block would have to be hand machined with a die grinder." The person who assembled the motor (me) should have checked all clearances. "I bet you will check that from now on." No ****
At first they were trying to say that pistons usually looked like that due to oil starvation or the cylinder wall clearances being too tight. I reminded them that they had the pistons and they checked the cylinder wall clearances when they bored the motor. And oil starvation on one cylinder? Once they acknowledged that the lip hitting the skirt was most likely the problem, they took the tack that their responsibility ended with the bore. Whatever. Like I said in the title of this post-" Check everything!". Live and learn
Old Oct 8, 2003 | 12:58 PM
b19coupe's Avatar
Default Re: (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">So it was orginally sleeved by GE, and then you had it bored to 85mm by a machine shop? Why not have GE do the whole thing?</TD></TR></TABLE>
Original bore was 84mm-this was the second incarnation of that block. No problems the first time, just looking for more power/compresssion.
Old Oct 8, 2003 | 01:40 PM
-KangaRod-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Well here is a surprise: the machine shop accepted ZERO responsibility.
At first they were trying to say that pistons usually looked like that due to oil starvation or the cylinder wall clearances being too tight. I reminded them that they had the pistons and they checked the cylinder wall clearances when they bored the motor. And oil starvation on one cylinder? Once they acknowledged that the lip hitting the skirt was most likely the problem, they took the tack that their responsibility ended with the bore. Whatever. Like I said in the title of this post-" Check everything!". Live and learn </TD></TR></TABLE>
Did you happen to mention you are one of the most respected members of the largest online Honda community, and the cornerstone of any advertising campaign? I'd think that competition in southern california would be such that they'd accept any sort of liability.
Old Oct 8, 2003 | 01:59 PM
Default Re: (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">
Did you happen to mention you are one of the most respected members of the largest online Honda community, and the cornerstone of any advertising campaign? I'd think that competition in southern california would be such that they'd accept any sort of liability. </TD></TR></TABLE>
Old Oct 8, 2003 | 02:01 PM
pro1342's Avatar
Ouch.....that sucks.
Old Oct 8, 2003 | 02:11 PM
Skeletor's Avatar
No pics. But that sounds crappy.
Old Oct 8, 2003 | 02:12 PM
Big Teggie's Avatar
Ouch...
What are your new plans?
Old Oct 8, 2003 | 02:20 PM
ALLMTRWHORE's Avatar
MAN THAT SUCKS! glad you have had a good experience with the ge sleeves and that you share your experiences with everyone and everyone benifits form it and can save money too!
good luck bro on your rebuild again! I know how it feel to build a motor and have the sleeves drop after a few runs not on just one but 3 of our motors it sucks but hey we have to learn somehow!
Old Oct 8, 2003 | 02:41 PM
b19coupe's Avatar
Default Re: Bad things can happen if you don't check EVERYTHING! (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">Ouch...
What are your new plans?</TD></TR></TABLE>
Hone the block if possible-if not. 86mm.
Got another block boring to 85mm-got new pistons. One way or the other, this thing is going to be up and running for Pomona.
Old Oct 8, 2003 | 02:43 PM
sleeprhatch's Avatar
Default Re: Bad things can happen if you don't check EVERYTHING! (ALLMTRWHORE)
that sucks d
