ITRs with Toda Bs, vlve adjustment?
Old Oct 7, 2003 | 07:46 PM
BlueR's Avatar
Default ITRs with Toda Bs, vlve adjustment?
i've had the valves adjust twice in the last 18 months/12,000 miles
and my valves a clacking like a **** again...
if this has any bearing:
1/3 miles are everyday driving
2/3 miles are to/from track and track itself
is this normal???
TIA
Old Oct 7, 2003 | 07:54 PM
Bbasso's Avatar
Default Re: ITRs with Toda Bs, vlve adjustment? (BlueR)
Marc, check your belt for any strech or play-
Old Oct 7, 2003 | 07:55 PM
BlueR's Avatar
Default Re: ITRs with Toda Bs, vlve adjustment? (Bbasso)
did that, its on there snug and nice
Old Oct 7, 2003 | 09:21 PM
Big Phat R's Avatar
try a higher weight oil?
15W50 quietens things up nicely!
Old Oct 8, 2003 | 05:13 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: ITRs with Toda Bs, vlve adjustment? (Big Phat R)
@ what cost to power.
Old Oct 8, 2003 | 05:51 AM
Willard's Avatar
I would check/adjust every other oil change.
Old Oct 8, 2003 | 05:00 PM
BlueR's Avatar
Default Re: ITRs with Toda Bs, vlve adjustment? (Willard)
so i'm right on schedule?
hmm....
Old Oct 8, 2003 | 05:06 PM
bus stop's Avatar
do you guys think timing may have something to do with it?
Old Oct 8, 2003 | 07:22 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">I would check/adjust every other oil change.</TD></TR></TABLE>
bah... i check mine oh... never.
Old Oct 9, 2003 | 11:58 PM
todapower's Avatar
valve lash for the spec b's is .008 all around, intake and exhaust... your going to have to stay ontop you your valve adjustments, your vtec lobe is 12mm, your obviously going to float your valves, especialy if you bring it up to 9,000...
Old Oct 10, 2003 | 03:18 AM
ITR764's Avatar
Default Re: ITRs with Toda Bs, vlve adjustment? (todapower)
what type of valve train/retainers are you using. the ti retainers will resonate more noise than stock...
fixed thanks to my spelling lesson from dick face yack...
Modified by ITR764 at 8:58 AM 10/10/2003
Old Oct 10, 2003 | 04:25 AM
B18CXr's Avatar
Default Re: ITRs with Toda Bs, vlve adjustment? (ITR764)
resinate
nice
Old Oct 10, 2003 | 04:42 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote"> my valves a clacking like a **** again...
wear a helmet.... the noise goes away
Old Oct 12, 2003 | 07:18 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR764 &raquo;</TD></TR><TR><TD CLASS="quote">what type of valve train/retainers are you using. the ti retainers will resonate more noise than stock...
Modified by ITR764 at 8:58 AM 10/10/2003</TD></TR></TABLE>
i'm using 98spec outers/portflow inners and portflow Ti retainers, stock redline for now
mugenboi
May 14, 2007 09:18 AM
Petah
Honda Civic (2001 - 2005)
Apr 26, 2007 03:07 AM
NomacGSR
Aug 1, 2003 05:19 AM
Lowez
May 19, 2002 04:00 PM
617arg
Aug 8, 2001 03:38 PM
