I have no clue which stage cams to run on my mildly modded GSR swap????
Old Oct 7, 2003 | 05:27 PM
BLK JDM's Avatar
Default I have no clue which stage cams to run on my mildly modded GSR swap????
I have read and read, searched and searched and I still can't decide whether Stage 2 cams are too big i.e. Skunk2 Stage2, EF-1 M22s. Would Skunk2 Stage 1 or CTR w/ ITR valvetrain be better. I keep reading different things from different highly regarded All Motor forum people.
The mods on my car are
98 GSR motor w/ 00 JDM ITR tranny
ClutchMasters Stage 4 Clutch
AEM Short Ram Intake
ITR TB
Skunk2 Intake Manifold
Thin Metal Headgasket
AEM Cam Gears
JDM DC 4-1 header w/ 2.5" collector(I may even buy an ANR from a friend)
CarSound 2.5" inlet/outlet Cat
Apexi N1 full catback exhaust
I know I need to upgrade the fuel w/ a fuel rail, fpr, and even a VAFC but which cams would yield me the best overall power through the powerband. This swap is in a 92 hatch CX w/ a GSR fuel pump and P28 w/ Mugen spec chip. This car is very much daily driven and I drive from SC to GA almost every other weekend.
Old Oct 7, 2003 | 05:40 PM
TimoneX's Avatar
New User
Default Re: I have no clue which stage cams to run on my mildly modded GSR swap???? (jigga008_99)
I would go with the ef-1 M22s & Hondata. Scrap the aftermarket fuel rail, Vafc, and Mugen chip.
Old Oct 7, 2003 | 06:06 PM
BLK JDM's Avatar
Default Re: I have no clue which stage cams to run on my mildly modded GSR swap???? (TimoneX)
Thanks anymore ideas. I am really considering the M22s just never considered the Hondata. Didn't think my car had enough work for it.
Old Oct 7, 2003 | 06:33 PM
TimoneX's Avatar
New User
Hondata does everything and more your chip & Vafc could do, just for less $$$.
Old Oct 7, 2003 | 07:08 PM
-KangaRod-'s Avatar
If you had a stock motor Hondata will still be a decent upgrade.
Old Oct 7, 2003 | 08:07 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">If you had a stock motor Hondata will still be a decent upgrade.</TD></TR></TABLE>True
Old Oct 7, 2003 | 08:14 PM
Mr Hammond's Avatar
a/k/a Jomo
Don't even buy cams if you have nothing yet to tune with. Skunk2 stage 1's for you my friend.
Or Skunk2 Stage 2's and P30 pistons.
Old Oct 7, 2003 | 08:22 PM
BLK JDM's Avatar
Default Re: I have no clue which stage cams to run on my mildly modded GSR swap???? (Mr Milano)
Believe me I'll get the Hondata if I need it.
Old Oct 7, 2003 | 11:03 PM
Rob Dizzle's Avatar
get hondata, cam gears, and a real header before you get cams.
Old Oct 8, 2003 | 08:25 AM
BLK JDM's Avatar
Default Re: I have no clue which stage cams to run on my mildly modded GSR swap???? (Bob-DC2)
I already have AEM cam gears as stated b4 and I have a JDM DC Sports 4-1 w/ 2.5" collector but I may get an ANR this weekend from UncleBen'sRacing.
If I buy cams/valvetrain I'll get the Hondata at the same time.
Old Oct 8, 2003 | 08:36 AM
GokuSSJ4's Avatar
skunk stage 2 w/ valvetrain are a nice upgrade . A management system always help to get the most out of them .
skunk stage 3 would be a bit to much lol , well at least till you get some nice forged pistons(with deep valve pockets) and a bit of higher CR to get the best out of them ...
Old Oct 8, 2003 | 08:54 AM
Rob Dizzle's Avatar
Default Re: I have no clue which stage cams to run on my mildly modded GSR swap???? (Spoon1)
https://honda-tech.com/zerothread?id=640147
hes has cams, but no hondata. a woping 158whp with stage 2 cams.
he could have only hit those numbers with hondata
https://honda-tech.com/zerothread?id=638917
Old Oct 8, 2003 | 11:01 AM
AnotherGSR's Avatar
I'd get different cam gears, AEM's often slip and break..
Old Oct 8, 2003 | 11:32 AM
turbo*s2k's Avatar
Default Re: (AnotherGSR)
When I was all motor... I had skunk2 stage 1 cams and enjoyed them. They work fine with stock valve train as well. Maybe go with the EF-1 cams, and EF-1 valvetrain. Whatever you go with... Get rid of that chipped ECU, and go Hondata!
REVolution
26
Aug 31, 2004 07:18 AM
s2k420
Oct 12, 2002 06:40 AM
flashgsr
Aug 28, 2002 07:40 PM
trillo
Apr 25, 2002 10:11 AM
