99 si suspension/rear break assembley
I just wanted to know if a 99 si suspension & rear break assembley would fit my 93 hatch ? Would i need to make any modificaton or is it a direct fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3minburnout »</TD></TR><TR><TD CLASS="quote">So what about the e-cables for the drum cars what has to be done so it could fit? Thanx</TD></TR></TABLE>
get SI cables, the ends of the cables are different. the drums use a molded steel barrel looking thing that attaches inside if the drum assembly (just like the end of the throttle cable. disc brakes use a flat u shaped end with a hole. you use a pin and a clip to hold it on the cable. just get the Si cables
http://www.hondaautomotiveparts.com/home.htm
#'s 17 and 18 are used on disc and #'s 5 and 8 are drums
carlos8
Oct 5, 2011 01:39 PM
Quiks66
11
Oct 22, 2005 10:20 AM
Hard2Find
Mar 12, 2002 07:43 PM
