Which engine should i go with???!!!!
Old Oct 7, 2003 | 04:21 PM
madhatter07's Avatar
Default Which engine should i go with???!!!!
alright guys, i figured how to make a poll now so now im cooking with gas here are my choices.
1) D16Z6 with high compression pistons, ecospeed head treatment (the 1300 dollar one) exospeed cam. The redline would be 8600 rpm
2) B18A1 with a B16 head both stock since that would probobaly be all i could afford
3) B18A1 block, stock with 65 shot nitrous
4) D16z6, stock head, block sleeved from exospeed and 125-ish direst port nitrous
i am tending to lean towards option 1 since that would be one ficking rev happy engine and if you guys have another suggestion hit other and let me know what you think.
the Total Budget for the swap would be 3000 dollars including everything!!!! mounts ect. let me know what you think. all combos would have a lighter flywheel and nice clutch
ok the GSR deal sounds really appetizing, if you think i should do that then vote other
Modified by madhatter07 at 11:02 PM 10/8/2003
Old Oct 7, 2003 | 04:27 PM
Big Phat R's Avatar
Default Re: Which engine should i go with???!!!! (madhatter07)
I say option 3 because it gives you the most options for change in the future and gives you the most displacement.
Old Oct 7, 2003 | 05:33 PM
pro1342's Avatar
Default Re: Which engine should i go with???!!!! (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">I say option 3 because it gives you the most options for change in the future and gives you the most displacement.</TD></TR></TABLE>
I agree, and it will probably be the fastest and most reliable, let alone the cheapest.
Old Oct 7, 2003 | 05:37 PM
TimoneX's Avatar
New User
Default Re: Which engine should i go with???!!!! (pro1342)
I would spring for a little bit more and shop around for a B18c for a few hundred more. Otherwise the B18a/b option with laughing gas is the best option.
Old Oct 7, 2003 | 05:53 PM
Default Re: Which engine should i go with???!!!! (TimoneX)
well i was thinking about that but i really either wanna stick with SOHC Vtec or the DOHC non vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimoneX &raquo;</TD></TR><TR><TD CLASS="quote">I would spring for a little bit more and shop around for a B18c for a few hundred more. Otherwise the B18a/b option with laughing gas is the best option.</TD></TR></TABLE>
Old Oct 7, 2003 | 05:58 PM
TimoneX's Avatar
New User
Any particular reason? The need to be different could well paint you into an expensive dead end here. If you go with the GSR motor you're almost certain to avoid future regrets.
Old Oct 7, 2003 | 06:05 PM
1OPTION's Avatar
Agreed.
Old Oct 8, 2003 | 04:20 AM
Default Re: Which engine should i go with???!!!! (1OPTION)
yeah that might be true, well we'll see what everyone else says too, another problem is my AC, thats half the reason i switched cars because this one has AC and thats tough to keep in a swap
ww3slayer
Aug 17, 2010 10:26 PM
madhatter07
Oct 7, 2003 07:54 AM
2camsaam
Nov 18, 2002 08:18 PM
89 CRX SI
13
May 26, 2002 12:37 AM
