AC compressor turns on and rpms drop?? Need help.
Old Oct 7, 2003 | 04:08 PM
Frankie324's Avatar
Default AC compressor turns on and rpms drop?? Need help.
On idle the AC compressor turns on and the rpms drop, when they drop below 500RPMS the whole car starts to shake, it sounds almost as if the car is going to shut off. How can i fix this??????
Old Oct 7, 2003 | 04:13 PM
99integralsturbo's Avatar
Default Re: AC compressor turns on and rpms drop?? Need help. (Frankie324)
my car does a similar thing, i would like to know too
Old Oct 7, 2003 | 04:18 PM
noble4ws's Avatar
lose the ac
Old Oct 7, 2003 | 04:21 PM
Highrevs99's Avatar
Your IAC should open up to compensate for load so it might be clogged so try cleaning it . If you have a chipped ecu , some of them disable the IAC . Usually thats the culprit .
Old Oct 7, 2003 | 04:23 PM
ScubaStevo80's Avatar
Default Re: AC compressor turns on and rpms drop?? Need help. (Highrevs99)
Mine does that occasionally also, it happened after i put my 4-1 header on... I would check the IAC like Highrevs99 said
Old Oct 7, 2003 | 05:28 PM
Frankie324's Avatar
Default Re: AC compressor turns on and rpms drop?? Need help. (VolpeOwnsU)
which is the IAC?? is it somewhere on the intake manifold or the throttle body?? how do i clean this valve, where do i spray it?? also the IAC is not the same as the fast idle valve because I have already replaced the fast idle valve because my idle used to go up and down, up and down from 2000 RPMS to 800 RPMS till i got it replaced.
Old Oct 7, 2003 | 08:59 PM
Frankie324's Avatar
anyone?
Old Oct 7, 2003 | 09:27 PM
falcongsr's Avatar
What is this crap?
iacv is the thing that bolts 27 and 28 go thru.
Old Oct 7, 2003 | 10:32 PM
Frankie324's Avatar
Default Re: AC compressor turns on and rpms drop?? Need help. (falconGSR)
how do you clean this???
Old Oct 8, 2003 | 01:50 PM
Frankie324's Avatar
how do you clean this thing??
Old Oct 8, 2003 | 04:36 PM
Frankie324's Avatar
!bump!
comon, someone has to know this??
Old Oct 8, 2003 | 05:00 PM
falcongsr's Avatar
What is this crap?
take it out and look at it. it will be obvious. there is a screen that might have crud on it.
Old Oct 8, 2003 | 05:38 PM
rainforest's Avatar
your idle air control valve can get carbon build up so heavy that can make it harder to move the piston inside it. your fix is to remove the iacv and spray throttle body cleaner in the ports on it. spray it one time and let it sit for 10-20 mins then spray again and let sit for the same ammount of time then while you are doing that you might as well clean the tb then when starting the car you will have to rev it a little bit to get the tb cleaner out off the combustion chamber and off the plugs then it will start and blow some carbon deposits out. you should be good after that.
Katastrophic
15
Jun 29, 2011 10:33 PM
Rooftop-Special
Sep 2, 2010 08:08 PM
Andrew14
Jun 22, 2010 09:24 PM
georgiajdm
Apr 6, 2010 04:44 PM
riceball777
Aug 18, 2003 10:11 AM
