would you rock autozone rotors (20$ each)? or brembro blanks for 126$ whole set?
Old Oct 7, 2003 | 12:52 PM
Seedc2's Avatar
Default would you rock autozone rotors (20$ each)? or brembro blanks for 126$ whole set?
I need to replace my rotors because they are warped to ****. Ive heard good things about autozone rotors for their price @ 20$ per rotor. I also came across a deal for 126 shipped for new brembro blanks (yes new). Im thinking about running stock pads all the way around with either setup. For those of you who are running autozones please share your thoughts about them.
What do you guys think? autozone or brembro.. heh brembro sounds so much better
Old Oct 7, 2003 | 12:57 PM
StyleTEG's Avatar
Default Re: would you rock autozone rotors (20$ each)? or brembro blanks for 126$ whole set? (kendogg)
rotors are a wear item, honestly I would save the cash and go for autozones since you will be replacing them at somepoint anyways.
Old Oct 7, 2003 | 12:59 PM
Seedc2's Avatar
Default Re: would you rock autozone rotors (StyleTEG)
good point...
also.. are there any pads that are similar to oem? but cheaper ?
now that you mention wear item.. didnt really think about that before.
Old Oct 7, 2003 | 01:01 PM
Caffeine Slug's Avatar
Default Re: would you rock autozone rotors (kendogg)
I've run the cheapest pad autozone carries in the past, they really weren't that bad. If you don't like them, not a big loss.
acuraholic's Avatar
I agree with StyleTEG. You can't even tell a difference between the two rotors when you compare them side by side. There's even a thread about it on here somewhere. For cheaper OEM-style pads, look into AEM maybe. If you can find them for a good price, go for it. They perform pretty much just like stock. Not bad for the money.
Old Oct 7, 2003 | 01:08 PM
Servo's Avatar
is running Autozone $20 front rotors on his Integra right now and will buy another pair if these ever warp.
BlueTeg's Avatar
Default Re: would you rock autozone rotors (acuraholic)
Autozone (Aimco) rotors will work for you just fine. I think a friend described it best when he used the term "throw away technology".
I use the AEM brake pads and they perform well. No squeaks, very low light colored dust.
Old Oct 7, 2003 | 01:13 PM
Stewie's Avatar
Default Re: would you rock autozone rotors (BlueTeg)
High quality rotors are painted inside so the don't rust. My friend works at a brake shop and says some rotors are such bad quality that they come warped right out the box. I would go with a good company.
I was also told that some brembo rotors are not made in italy and are bad quality.
Old Oct 7, 2003 | 01:15 PM
Seedc2's Avatar
Default Re: would you rock autozone rotors (Mac8008)
so what would be considered "good" rotors?
hm.. okay I just went to autozone.. and they said 21.99each for front and 49each for rears.. someone enlighten me..
its strange that the rears are significantly priced higher than the fronts.. id imagine the opposite. I asked the autozone guy why there was a huge difference in price and he says "maybe there are sensors for the rears".. I called another autozone just in case the previous guys just quoted me incorrectly.. but nope.. its correct 21f/ 49r... I asked this guy what the difference was and he says "its probably more because we have to special order it, its probably the shipping costs" on autozone employees
Modified by kendogg at 2:58 PM 10/7/2003
Modified by kendogg at 2:59 PM 10/7/2003
Old Oct 7, 2003 | 01:49 PM
juggernaut's Avatar
$126 you can find them on ebay for like 60-80 for cross drilled.
Old Oct 7, 2003 | 01:52 PM
Seedc2's Avatar
Default Re: would you rock autozone rotors (juggernaut)
im not looking for cross drilled.. just blanks
Old Oct 7, 2003 | 01:56 PM
riceball777's Avatar
i just changed my rotors and i got the brembo x drilled and sloted for $50 each for the fronts
works fine to me and looks cool too
Old Oct 7, 2003 | 02:22 PM
obd2gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">rotors are a wear item, honestly I would save the cash and go for autozones since you will be replacing them at somepoint anyways.</TD></TR></TABLE>
i agree... things you replace often don't need to be of the highest quality, unless you're racing. autozone gets a from me for regular maintanence parts.
Old Oct 7, 2003 | 02:23 PM
P1mpSlap's Avatar
I rock some Autzone rotors. They pretty much suck so I replace them whenever I get some free time and cash.
Old Oct 7, 2003 | 02:35 PM
BlackThorN's Avatar
http://www.cobaltfriction.com
if you drive like a maniac you'll warp cheap rotors...I do....get something quality, brakes may be a wear item but stopping is somewhat important
NIck
Old Oct 7, 2003 | 02:40 PM
Blk95GSR's Avatar
Default Re: (BlackThorN)
autozone blanks + Hawk HPS pads
Old Oct 7, 2003 | 02:52 PM
wall of tvs's Avatar
Default Re: (Blk95GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk95GSR &raquo;</TD></TR><TR><TD CLASS="quote">autozone blanks + Hawk HPS pads </TD></TR></TABLE>
Yup -- that's my plan once I need some new pads.
Old Oct 7, 2003 | 03:00 PM
SilverDc2's Avatar
Default Re: (wall of tvs)
i get brembo crossdrilled and slotted for 36, and blanks for 21 out the door no tax....so cali of course
PS : i do not sell them i know a shop that does......
Old Oct 7, 2003 | 03:05 PM
R.S.'s Avatar
Default Re: (SilverDc2)
i'd go wit brembo blanks, those are the ones that i will be gettin
Old Oct 7, 2003 | 03:13 PM
Trac226's Avatar
Default Re: (-R-)
Even with new rotors, I still do a light resurface on them to make sure they're to spec and elimante chances of noise.
Old Oct 7, 2003 | 03:58 PM
IntEGNYC's Avatar
Default Re: (Trac226)
get blanks, but dont scrimp on the pads. Get good ones and they wont squeel or screech on ya.
Old Oct 7, 2003 | 04:30 PM
integra15's Avatar
$49 would be a rip off considering I just paid $17 at Autozone for one rear rotor. Go somewhere else to buy them
Old Oct 7, 2003 | 05:09 PM
Vitt1's Avatar
Default Re: would you rock autozone rotors (integra15)
Did you check Autozone online? They cost cheaper than the front ones for my GSR. Also, are you sure you can't just turn the rear? In any case, you'd only be saving about $17 since that's what they cost each and that's the price to turn 2 rotors in my area. For pads, also check Axxis Ultimates. http://www.carbotecheng.com has really good prices. I would go with those for front and OEM for rear.
Old Oct 7, 2003 | 05:46 PM
99GEEzer's Avatar
doesnt autozone have lifetime pads and rotors... like u can bring in old rotors and they'll replace it
Old Oct 7, 2003 | 06:01 PM
Rory Breaker's Avatar
Default Re: (99GEEzer)
90 Day warranty.
I would go with Autozone.
