ok..need help from the tech guys
ok, my car if finaly running. with one minnor problem. the fan for the radiator seems to kick on when ever it wants to. the fan control unit behind the radio seems to be ok. i'm gonna try swapping in another one next weekend. now the fan turns on even with the key off and the engine cold as hell. so what could be some potential problems? let me know what you think.
oh...i have a 91 integra ls 5spd with a 98 b18b engine converted over to obd0. all the sensors from the old engine are in the same spots on the new engine. thanks.
does your new block have this sensors?
you see the ones near the oil filter
3 of them...
one gray plug
one green plug
one with little plugs
yes they do. the oil pressure is moved to accomadate a oil pressure sender. but i have those. and i know the water temp sender works cause the dash gauge moves. its something in fan control i think.
