Wiring F23 to 92 Accord
Old Oct 7, 2003 | 10:35 AM
purpl7duece's Avatar
Default Wiring F23 to 92 Accord
I am gonna do a f23 swap in my engineless 92 accord and I want to see if me and my boys can do it ourselves or if i will have to take the harness to get done. I know you have to wire it up for an internal coil but is there anything else? Can i use the Accord ECu until I find a F23 ECU? Thanks in advance
Old Oct 7, 2003 | 12:28 PM
f22a's Avatar
Default Re: Wiring F23 to 92 Accord (purpl7duece)
you should convert it to obd1 by using an obd1 ecu, distributor, anmd injectors
you can use your ecu but if your f23 is vtec, it wont work and you probably wont be getting maximum performance out of it. i would get a 94-95 f22b1 ecu
and when it comes time to wire for vtec, its three wires.. you will need to wire up the iab if you want if the f23 has dual runners but im not sure.. or you could just run straight vacuum like v4lu3s is
Old Oct 7, 2003 | 01:42 PM
Default Re: Wiring F23 to 92 Accord (f22a)
Damn I'm a idiot. It is a H23 not a F23. Thanks for the info above though.
Old Oct 8, 2003 | 07:16 AM
h22aLSD
Guest
Posts: n/a
everything should plug up because both are obd1 if anything the injector clips and dist will be the only things
Old Oct 8, 2003 | 07:31 PM
CityHunt3r's Avatar
Default Re: Wiring F23 to 92 Accord (h22aLSD)
how can u tell the difeeance between h22 n h23 what car comes with h23 stock????? and what year
Old Oct 9, 2003 | 10:09 AM
iam7head's Avatar
Default Re: Wiring F23 to 92 Accord (CityHunt3r)
h23-most of the 4th gen prelude
heopmarine
Feb 6, 2015 11:24 PM
tigerr227
Feb 8, 2008 01:43 PM
jdm monkey
Feb 20, 2007 05:36 PM
showbiz
Nov 21, 2004 06:46 PM
