>>> Need a frankinstein zdyne base .... help
i have currently a b20 with a great tune ... running 12 psi on a t3/t4 with a 70 trim ... spools great and did many (like 20 5th gear pulls) hard runs to prove my tune so i understand 100% or at least close to perfect tuning but now i want more.. i want to add a 16a1 vtec head to my setup and wanted to see if anyone has a tune for a base that i can tune off of .... i have the zdyne gold and have a lot of time to tune it... also can i run 12psi like now with the addition of the head if i have proper fuel and conservative timing curves... thanks
Your post is very vaige. Whats your:
1)injectors size
2)displacement & compression
3)complete mods
4)what grade of gas do you run
1)injectors size
3)complete mods
i have dsm 450's going to 720-800's ... run 94 all the time or higher, will be stock b20 bottem with b16a head i have older 8.8:1 b20 so it will be about 9.5:1 without thick headgasket.... i just need a base tune i can adjust the fuel for injectors and tweak it to fit my setup just need a running base to do so ... also would modding a b16a work ???
t3/t4 60/63/70 trim
inline pro mani
tial 35
tyrus intercooler
---soon to add stock b16a head with maybe gsr cams but it will be stock top/bottem
t3/t4 60/63/70 trim
inline pro mani
tial 35
tyrus intercooler
