About four wheel drive?
Old Oct 7, 2003 | 09:35 AM
Root79's Avatar
Default About four wheel drive?
There is posibilitie to built for wheel drive EG, EK or Prelude Honda?
I'm from Europe and we dicide that is not posible. Did you Guy's in US do something like this, ore there is some modifaided with 4x4?
Old Oct 7, 2003 | 10:02 AM
Diablo Tejano's Avatar
Default Re: About four wheel drive? (Root79)
There was a post a while back, where a guy swapped the drivetrain out of a CR-V into a CR-X with a boosted b18c1. It seemed like a really good idea, but the rear axles are very thin, and they seemed like the would not hold up to too much abuse.
It's possible, it will just be a lot of work.
Good luck!
jM
Old Oct 7, 2003 | 10:22 PM
greebler's Avatar
Default Re: About four wheel drive? (Masekja)
Only if you are able to design a tranny/differental that will work. In short, no way in hell........
Old Oct 8, 2003 | 03:56 AM
jerseybrandon's Avatar
Can be done, more hassle than its worth.
Old Oct 8, 2003 | 09:56 AM
Root79's Avatar
Default Re: (jerseybrandon)
Are CR-V not the same base like EK Civic? Maybe that's why they use this 4X4 system.
Old Oct 8, 2003 | 10:33 AM
1_bad_EF's Avatar
Honda-Tuning magazine is doing a 4x4 ITR using a 5sp trans and diff from a 5sp CRV. It does work, however you must make a rear differential mount and cut the body out somewhat. You also have to modify the trailing arms so the crv hubs will fit.
Old Oct 9, 2003 | 06:10 AM
Root79's Avatar
Default Re: About four wheel drive? (1_bad_EF)
there is E-link, home page to that magazine?
RideBride
Feb 7, 2007 08:47 PM
ENJOI
Jun 9, 2006 02:30 AM
b18c1eg
Jun 21, 2004 09:03 AM
HotWheelz
Oct 11, 2002 10:11 PM
