Buying a used type-R
Old Oct 7, 2003 | 08:54 AM
lastlude2k1se's Avatar
Default Buying a used type-R
Going to check one out this weekend, a CAN 2000 PY. It's been winter driven but seems to be in mint condition.
Anything in particular to check when buying a used type-r?
Thanks
Old Oct 7, 2003 | 09:06 AM
Bbasso's Avatar
Default Re: Buying a used type-R (lastlude2k1se)
Just read thru all the top posts and take notes on whats a possible problem, I have yet to see many problems except for driver induced. Such *** bad clutches, popped cv joints and slow moving windows.
How many miles on the caR and where is it located maybe a member here could help you take a look?
Old Oct 7, 2003 | 11:06 AM
George H's Avatar
You can also pay to get the car inspected at a local Acura dealer. I believe the charge is around $70 and they run it through the same process they use to certify their used cars. Its definitely worth the money.
Old Oct 7, 2003 | 01:02 PM
Default Re: Buying a used type-R (George H)
Well the car is located in Calgary Alberta Canada.
I will be getting the car inspected and getting a compression test from the Acura dealership. I guess that should be good enough.
Hoplefully I will be a new R owner
Old Oct 7, 2003 | 02:33 PM
EkEli's Avatar
rebmem roines
Good luck on your new R. Madx is a r owner in edmonton and there are some other members also. Is it the PY or CW R your looking at in Calgary?
https://honda-tech.com/zero...00974
Old Oct 7, 2003 | 02:40 PM
jdmspoonitr's Avatar
Default Re: (bruce_eli)
I would make sure that there is no damage to the body due to the salting of the roads in winter. Besides that make sure that the tranny is snoothe as silk.
Old Oct 7, 2003 | 03:34 PM
Hey, is MadX the guy with the JDM front conversion, on a 97 CW? If it is I know him hehe
Old Oct 7, 2003 | 05:08 PM
EkEli's Avatar
rebmem roines
No clue about his JDM front conversion, Just saw him posting a tread about trying to start a R meet. I know there is one member from sherwood park that is a really cool guy that would help yea out somewhat.
<<<<Eli- A guy that dreams of having the privilage of owning a Arrr one day.
Old Oct 7, 2003 | 05:26 PM
1OPTION's Avatar
I can do an inspection myself, but if you can't, i suggest you take it to the dealership to have it checked out. Definitly worth the time/Money.
OEMJDM
Acura TSX
Mar 26, 2015 10:42 PM
Demonis
Honda Civic (2006 - 2015)
10
Aug 4, 2007 05:08 PM
99_IntegR
Jul 13, 2004 03:54 PM
rickpeak
Acura TL, RL & ZDX
Sep 10, 2003 12:19 PM
Veritas-Aequitas
Aug 19, 2002 09:30 PM
