Camber issues...please help
Old Oct 7, 2003 | 07:56 AM
bartek_b's Avatar
Default Camber issues...please help
Hey guys, I have a 1994 Honda civic Coupe and I went to have my alignment done but they weren't able to start it because the tests on the machine showed that my alignment is off 1degree.
The tech told me to get a camber kit for the rear and front and now that's where I'm stuck at.
I have no idea what kind camber kit I should get.
I was quoted $400.00-/+ for a Ingals(SP?) camber kit for the front and rear.
I'm just wondering, does anybody know what kind kit I should get for my car??? or what I should do about my camber issue??
thanks
bartek
Old Oct 7, 2003 | 08:05 AM
TimoneX's Avatar
New User
Default Re: Camber issues...please help (mugen85r)
The Ingalls kits work fine. I assume you lowered the car?
Old Oct 7, 2003 | 08:36 AM
pro1342's Avatar
Ingalls is good for the front and rear. But, to save some cash, you can just shim the rear upper control arms out to spec with shims or washers.
Old Oct 7, 2003 | 08:37 AM
SpyderZEX's Avatar
Default Re: Camber issues...please help (TimoneX)
I would run a search on "rear camber kit" or "washer camber" for a how-to on doing the rear camber. There is a trick that you can do, to adjust the rear camber without having to buy a camber kit. It involves using washers as spacers in the rear. I don't really have time right now to get into it, but you should not have a problem finding this information on this site. That way you will only need to buy camber kits for the front.
Hope this helps, or maybe somebody else can fill you in on the "Washer Trick".
^--^ see I told you somebody could help you with this.
Old Oct 7, 2003 | 09:06 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: (pro1342)
Save even more money by doing the washer trick in the rear, and having the alignment shop bend your forks up front.
Old Oct 7, 2003 | 09:16 AM
TimoneX's Avatar
New User
Default Re: (KURRRWA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRWA &raquo;</TD></TR><TR><TD CLASS="quote">Save even more money by doing the washer trick in the rear, and having the alignment shop bend your forks up front.</TD></TR></TABLE>
Don't do that. The washer trick is one thing, but bending the forks is silly, even if you can find a trustworthy tech to do it.
Old Oct 7, 2003 | 10:34 AM
bartek_b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">Ingalls is good for the front and rear. But, to save some cash, you can just shim the rear upper control arms out to spec with shims or washers.</TD></TR></TABLE>
I was thinking about that.
yes my car is lowered on tokico blue and coilovers .
Old Oct 7, 2003 | 10:43 AM
gloryhog's Avatar
I have the same car and same suspension setup, I saved and got the spc adj. balljoints for the front and the adj. control arms for the rear, I think it cost me 280.00 shipped from ard performance.com, the spc kit is some quality stuff and it is a piece of cake to install.
good luck!!!!
Old Oct 7, 2003 | 01:00 PM
htownteg's Avatar
im sitting on tokico illuminas and GC coilovers...130shipped for ingalls on the front..and just add shims to the rear...
Old Oct 7, 2003 | 02:11 PM
bartek_b's Avatar
Default Re: (htownteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by htownteg &raquo;</TD></TR><TR><TD CLASS="quote">im sitting on tokico illuminas and GC coilovers...130shipped for ingalls on the front..and just add shims to the rear...</TD></TR></TABLE>
what do you mean shims??? washers????
Old Oct 7, 2003 | 02:32 PM
TimoneX's Avatar
New User
Default Re: (mugen85r)
They're talking about putting washers behind the upper arms in the rear to move the top of the rear wheels away from the centerline of the vehicle. The right way is to use a camber kit for the rear too, but this does work.
Old Oct 7, 2003 | 04:45 PM
Riceburner247's Avatar
Default Re: (TimoneX)
check the members corner, I think i saw a 20% off special on camber kits.......
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
fafsa
Apr 6, 2005 03:40 PM
Takeoff
Aug 11, 2002 01:08 PM
vtec-outlaw
Mar 13, 2002 09:34 PM
