JIC FLTA2 Info needed
Old Oct 7, 2003 | 07:49 AM
fireant's Avatar
Default JIC FLTA2 Info needed
RSX/EP3 JIC owners, what are the modifications needed to install, and what are the spring rates?
Also, who sells the EP3 application? I can only find the RSX. Any info would be appreciated.
Old Oct 7, 2003 | 09:56 AM
fireant's Avatar
Default Re: JIC FLTA2 Info needed (hatch2k)
OK, I did some digging and found a little more info on fully adjustable coilover systems for the EP3:
JIC FLTA2
MSRP: $1980
F: 448#
R: 504#
direct bolt-on; 15-way adjustable bound only
KW V2's
MSRP: $1435
F: 340#
R: 500#
direct bolt-on; stainless steel construction; lighter than stock; optional quieting kit sold separately. rebound adjustable
Tein Flex
MSRP: $1860
F: 448#
R: 560#
direct bolt-on; teflon-coated steel; 16 way adjustable (bound/rebound together); EDFC compatible.
Modified by hatch2k at 12:33 PM 10/8/2003
Modified by hatch2k at 12:34 PM 10/8/2003
Modified by hatch2k at 11:39 AM 10/10/2003
Modified by hatch2k at 11:40 AM 10/10/2003
Modified by hatch2k at 5:42 PM 10/10/2003
Old Oct 7, 2003 | 04:44 PM
Todd00's Avatar
I said I don't want a title!
Flex's are a direct bolt-in for the EP3--no modifications to car or shocks.
The Tein SS needs holes enlarged.
And not DOT approved? You lost me there. Since when does any aftermarket suspension say DOT approved. I think you're over-analyzing things.
Old Oct 7, 2003 | 04:46 PM
Essence of Chicken's Avatar
I have the Jic magic rs suspension, but I have yet to put it on my car yet. I am in my first season of autox and these suckers are just seating in my room along with the azenis, and comptech header. I want to be sure that I developed the skills before upgrades. Btw, the jic flta2 is a direct bolt on if you get it for the ep3, assuming thats what you have. My sping is customized, with race dampers and helper springs.
Old Oct 8, 2003 | 09:32 AM
fireant's Avatar
Default Re: (Essence of Chicken)
Thanks for the corrections guys, I'll put them in now.
Yes, I do over-****-ize everything.
Old Oct 8, 2003 | 10:36 AM
If you like you can come down to one of houston's regional events sometimes during dec. or jan. (which ever is the 1st regional of the new season), I think by that time I will have the jic's installed.
Old Oct 8, 2003 | 11:16 AM
fireant's Avatar
I think i might. 2 of our local clubs are having a hard time finding sites.
Old Oct 9, 2003 | 11:42 PM
Suk02Si's Avatar
Default Re: (hatch2k)
I wanted the JIC FLT A2s but I heard they had rist issues, can anyone confirm this?
Old Oct 10, 2003 | 05:44 AM
GoodKnight's Avatar
Default Re: (Suk02Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suk02Si &raquo;</TD></TR><TR><TD CLASS="quote">I wanted the JIC FLT A2s but I heard they had rist issues, can anyone confirm this?</TD></TR></TABLE>
The only rust issue is that you should never see any
I have these on my dc5, and I got them after talking heavily with a lot of other coilover owners. They seemed like the best compromise between track/street driving. Not too stiff for the streets, and not too soft for the track. You shouldnt have any problems installing them on ur car, provided u purchase ur model specific application.
Old Oct 10, 2003 | 08:40 AM
fireant's Avatar
Default Re: (GoodKnight)
I just updated the JIC info on my original breakdown above.
Old Oct 10, 2003 | 02:19 PM
You want the real weights of jics. Its 55lb for all 4 corner, 16lb for each front, 34.5lb for both front, 11.5lb for each rear and 24lb for both rear.
Old Oct 10, 2003 | 02:51 PM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Essence of Chicken &raquo;</TD></TR><TR><TD CLASS="quote">You want the real weights of jics. Its 55lb for all 4 corner</TD></TR></TABLE>
Is that for the EP kit?
Heh, I knew the JIC guy wasnt sure when he told me 9lbs.
I called Tein, and they say the whole package is 63lbs (including the box and the wrenches, so give or take a couple)
NOW we're getting some good info! Thanks!
Old Oct 10, 2003 | 02:57 PM
This is for the Jic flta2 RS not flta2, but they look similar, just got some extra stuff btw.
Old Oct 11, 2003 | 11:30 PM
muse's Avatar
Goodknight, what did you pay for your set? Just curious because I am applying to become a JIC dealer, and the discounts look pretty fair.
I can ask my rep about EP3 availability and spring rates monday.
Old Oct 12, 2003 | 08:55 AM
fireant's Avatar
Default Re: JIC FLTA2 Info needed (George Knighton)
Yep, I wonder the same, George. Currently, Im planning on going with the JICs with stepped up springs. (cost $90 extra per corner). I like the Mugen setup, but I want to twiddle and adjust everything.
Muse, it looks like at first, JIC was offering an RSX kit only, that required some cutting and RSX control arms to work on the EPs. Now, apparently since Sept. or so, they have a specific application for the EP that bolts right on (probably some slight clearance and steering boss changes were made to the RSX versions).
I am anxious to get a good setup, but Im trying like hell to be patient and give KW a chance to present thier V3's late November.
Old Oct 13, 2003 | 05:19 PM
muse's Avatar
Okay, well there is an EP3 Specific Kit, and they are currently available in the FLTA2 (inverted monotube, 15-way adjust) . I was told that the spring rates come the same as the RSX (8k front and 9k rear) but you will be tweaking that as well.
I'd like to post my price but I am only allowed to post 10%off list, PM me though, I think you'll be pleasantly surprised.
Old Oct 13, 2003 | 08:43 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
Looking at the spring rates you've quoted, I am wondering why more people don't just get the no-brainer Mugen Sport Showa Suspension.
?</TD></TR></TABLE>
Mugen Sports just have zero adjustability in every aspect, thus making them nothing better than a good street suspension IMO. Not cutting on them, but they are what they are. If you plan on doing nothing more than driving your car daily and want a good matched damper set, then Mugen is the answer. But if you like to tweak your suspension (camber, shocks, ride height), look somewhere else.
And I see my guess on the weights of the Tein Flex was decently accurate.
Old Oct 14, 2003 | 05:23 AM
GoodKnight's Avatar
Default Re: (muse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muse &raquo;</TD></TR><TR><TD CLASS="quote">Goodknight, what did you pay for your set? Just curious because I am applying to become a JIC dealer, and the discounts look pretty fair.
1600 otd.
Old Oct 14, 2003 | 06:05 PM
Dont you just love that price . Mine is cost a bit more with all the goodies.
845_dapek
Feb 13, 2009 10:14 AM
kaliboy562
Oct 17, 2008 07:21 AM
ef8status
Oct 14, 2008 06:18 PM
danthemang3
Aug 21, 2007 02:00 PM
TurboAce
Aug 16, 2002 09:57 PM
