Cold morning start + shift into gear = car chokes and dies... help?
Old Oct 6, 2003 | 09:15 PM
dclub01's Avatar
Default Cold morning start + shift into gear = car chokes and dies... help?
Lately my car has been acting up in the mornings... when i go to start it and shift into gear, the car begins to choke up and almost dies (it dies totally sometimes). If I let it start for 5 minutes or so, then it's jus fine.
I know i should let my car idle to normal tempurature, but there's those times when u r in a rush...
What causes this? Forgive the noob question, but it's never done this b4...
Modified by dclub01 at 8:40 PM 10/7/2003
Old Oct 7, 2003 | 11:41 AM
dclub01's Avatar
Default Re: Cold morning start + shift into gear = car chokes and dies... help? (dclub01)
bump
Old Oct 7, 2003 | 01:10 PM
JimBlake's Avatar
'91 is too old for me, so I'll just kinda guess...
On my newer cars, it works like this. When the transmission is in gear, there's a signal to the ECU, then the ECU opens up the IAC valve a bit to raise the idle. Maybe that signal from the shift lever to the ECU is disconnected?
Some older cars used a separate solenoid valve that opens with the transmission switch. Just like the IAC valve, it lets some extra air get thru to raise the idle a bit. I don't know if '91 had that older kind of system.
Old Oct 7, 2003 | 03:27 PM
teamlegacy's Avatar
Default Re: Cold morning start + shift into gear = car chokes and dies... help? (JimBlake)
my 5th gen does some really random stuttering after starting sometimes. it'll jerk really hard and feel like it's stalling out. but like i said, its very random. can be at cold starts or warm starts. it's strange.
must have something to do with IACV or TPS.
Old Oct 8, 2003 | 08:45 AM
dclub01's Avatar
Default Re: Cold morning start + shift into gear = car chokes and dies... help? (teamlegacy)
thx a lot, i'll look into it, but can anyone explain why it works well after a letting the engine warm up? yeah, total newb question here...
Old Oct 8, 2003 | 09:49 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dclub01 &raquo;</TD></TR><TR><TD CLASS="quote">... can anyone explain why it works well after a letting the engine warm up?</TD></TR></TABLE>If the IAC valve is sticking, then when you put the auto trans in gear the idle rpms drop too much. Once the IAC valve gets warm & shook up a bit maybe it works better... Plus, when the engine's warm the IAC valve can hold a good idle without opening up quite as wide.
jeffbrewer80
Nov 4, 2011 06:00 AM
schueytenten
11
Apr 10, 2011 02:43 PM
dubedone
Nov 21, 2009 08:48 PM
kroze
Jun 6, 2009 10:27 AM
DCFIVER
Jun 10, 2005 10:57 AM
